Modding What kind of switches can be used in a 12v molex lines to turn off fans/ccfls etc.
Discussion in 'Modding' started by retrogamer, 24 Jun 2005.
  1. retrogamer
    retrogamer What's a Dremel?
    23 Aug 2004
    Im not an electrically minded guy and I dont have a clue about amps and current etc, so ratings of switches confuse me :confused:
    Can anyone link me to some toggle switches or nice lookin switches of any kind that I could use to turn off fans when theyre not needed? Preferabley in the UK but other links may help me to learn :D Been looking around maplins website and just confusing myself even more :hehe:
    Cheers
    Retro
  2. Atomic
    Atomic Gerwaff
    6 May 2002
    Pretty much any switch will do that.
    Post some you like and we'll tell you if they'll manage it.
  3. retrogamer
    23 Aug 2004
  4. Atomic
    Atomic Gerwaff
    6 May 2002
    Yeah they'll manage it no problems!
  5. Zidane
    Zidane What's a Dremel?
    27 Apr 2004
    im no electronics expert, but i tend to find most fans and such have a sticker on them somewhere saying something like "12V 0.14A" or similar. i just added up the amps (i figured that the 12v would remain constant and the amps would increase) and checked against my switches. most of them were rated like the switches you posted, like 120V 1A, so as long as i stay under 1A, i figure my switches will be fine. saying most of my fans are somewhere around 0.12 amps, i have plenty of margin.
    this is probably the part where someone who actually knows something about electronics posts something like "omgomgomg how have you not blown yourself up yet! this is how you work it out!"
  6. Da Dego
    Da Dego Brett Thomas
    17 Aug 2004
    j/k. :D
  7. Zidane
    27 Apr 2004
  8. retrogamer
    23 Aug 2004
    lol, righto thanks for the info :)
    *goes to order some switches :D*
    Retro
  9. Cowcharge
    Cowcharge What's a Dremel?
    27 Jan 2005
    automotive switches are built to take way more amps than a computer will ever put out, and are 12v too...
  10. Ghlargh
    Ghlargh What's a Dremel?
    16 Nov 2003
    Automotive switches are made for a DC load, a switch designed for only AC loads will often need to be downmarked for DC application.
    Example: a switch that can handle 1A 24V AC, can in a worst case scenario break from as little as 0.1A 12V DC. Not immediately ofcourse, but after relatively few operations.
    This is especially true if you are running non resistive loads such as fans and CCFL inverters, wich have a high innitial load, and are inductive.
    A DC inductive load will wear down the contact elements really fast in a switch not made for DC operation.
    Allso, the marking on a switch is allmost allways for resistive loads.
    Mark down the current if you are running DC on a switch marked only for low voltage AC (from what i have found, the 12V DC current tolerance is usually near the 250V AC current tolerance for a great part of switches, this is a fairly good comparison to remember)
    Mark down the current if you are running non-resistive loads (in computers, anything that is not a LED or peltier).
