Equipment What lens to take travelling
Discussion in 'Photography, Art & Design' started by sotu1, 17 Aug 2013.
  1. sotu1
    sotu1 Ex-Modder
    24 Aug 2007
    Hi guys, I've got a holiday coming up shortly to Spain and Italy, mostly cities like Barca, Rome, Venice.
    I'm taking my DSLR (nikon 3200) but wondering what lenses I should take/buy?
    I have an 18-55, a 50, and am considering buying a tamron 18-270 (£330)
    What would you do?
    Thanks!
  2. djzic
    djzic Bokehlicious!
    8 Nov 2010
    Depends on what kinds of things you like to shoot, and whether you need/want a fast aperture.
    I'd say a 35mm lens is pretty essential, the AF-S DX 35mm f/1.8 is meant to be great value for money, but with 35mm vs 50mm it really comes down to preference, the 50mm will have shallower depth of field. Also I'd take the 18-55mm so that you have the wider end covered. A decent telephoto is good to have as well, say something like this 75-300mm. Steer clear of ultrawide to telephoto lenses, they'll be unsharp, full of chromatic aberration and have less contrast.
  3. Silver51
    Silver51 I cast flare!
    24 Jul 2006
    I took a bunch of lenses on holiday. Ended up using a Sigma 18-50 f/2.8 mostly, followed by a Pentax 18-135 WR.
  4. GeorgeStorm
    16 Dec 2008
    I think it really depends exactly where you'll be going/what you'll be doing, and most importantly what kind of photos you like taking/want to try to take.
  5. RinSewand
    RinSewand What's a Dremel?
    11 Sep 2006
    Borrowed a friends 18-135 last time I went. Worse IQ than the 17-50 Tamron that broke the day before I left, or the 70-200L, but I wouldn't have changed lenses half the time and the weight would have annoyed me over 20 miles of walking each day. The best lens is the one you have with you ;)
  6. LennyRhys
    LennyRhys Oink!
    16 May 2011
    Standard zoom is all you need. I'm just back from holiday and the only lens I used was my 24-85. :thumb:
  7. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Recently picked up a secondhand-mint Canon 24-105 F4L for just this purpose (Trip to Texas in 2 weeks!).
  8. C-Sniper
    C-Sniper Stop Trolling this space Ądmins!
    17 Jun 2007
    Get a standard zoom. 24-85, 18-55, or 18-135. IQ is not as great but again weight can get annoying. I just got back from Russia toting around my D7000 and 17-35 f/2.8 D and i can tell you that it does get heavy quickly
  9. Xir
    Xir Modder
    26 Apr 2006
    Well the 18-55 kit lens is light and pretty good.
    I personally love the 35mm 1.8, but if I could take just one lens, it's just not wide enough, so I'd take the kit lens.
    Of course if you find an 18-200 you like you're set.
  10. lysaer
    lysaer Suck my unit! Kirk lazarus (2008)
    15 May 2010
    I'd go on ebay and get yourself a nice used 24-70/2.8 sigma lens.
    You won't regret it, it's a lot better than the tamron lens and you will probably get it a few quid cheaper
    Sent from my GT-I9505 using Tapatalk 2
  11. Atomic
    Atomic Gerwaff
    6 May 2002
    In an Urban environment the 18-55 should be fine, most things you'll want to shoot will be close to you so the wide end will be more use than a zoom.
  12. wyx087
    15 Aug 2007
    Fantastic lens, holiday in Edinburgh, Paris and along England South coast all using this single lens. Took 2 others but they were rarely taken out of the bag.
    For a prime, get 35mm equivalent. If I can only get 1 prime, I'd get this....... in fact I did with Fujifilm x100 :D I'll be going on holiday to China end of this year travelling mostly with this camera and 35mm equivalent lens. Only taking the DSLR out of the hotel for specific photography trips.
    For travelling, take the least amount of stuff you can get away with. You want to work to get that photo while enjoying the moment, not work to carry those gear.
  13. sotu1
    sotu1 Ex-Modder
    24 Aug 2007
    I'm tempted to go with just the 50mm prime....but wish it didnt scale up to 85mm on a digital....
  14. bdigital
    bdigital Is re-building his PC again
    10 Aug 2010
    Nice for portraits but I think you might find it annoying when wanting to shoot something wider like a landscape or building.
    I would take the zoom and pack the 50mm prime anyway (its very small and light)
    Sent from my GT-I9505 using Tapatalk 4
  15. sotu1
    sotu1 Ex-Modder
    24 Aug 2007
    Ok, I guess it's decided then, will bring the Kit lens + the 50, but will probably end up sticking with the 50. I'll save up for the 18-200....
    Worth picking up a flash gun and taking that?
  16. wyx087
    15 Aug 2007
    18-200 while nice zoom, usually have terrible image quality. I had the Nikkor 18-200, very nice build quality and image quality at lower focal length but it was terrible from 100mm onwards. Might as well buy a 16-85mm which has better image quality all around.
    I personally dislike any use of on-camera flash, except for fill flash during sunny days. With that in mind, I don't think it's worth packing a flashgun for holiday.
    If you've got money to spare, have you considered getting the 35mm f2 or Sigma 30mm? They are slightly more expensive but the focal length are infinitely more useful than 50mm on APS-C sensor.
  17. lysaer
    15 May 2010
    If you want a nice range of high quality lenses I would recommend this for your bag
    http://item.mobileweb.ebay.co.uk/viewitem?sbk=1&nav=SEARCH&itemId=161086157338
    http://item.mobileweb.ebay.co.uk/viewitem?sbk=1&nav=SEARCH&itemId=271259959096
    http://item.mobileweb.ebay.co.uk/viewitem?sbk=1&nav=SEARCH&itemId=281115167611
    That setup will cover you for just about any eventuality, they are all the same aperture through the lens as well so when you zoom in and out there is no faffing around with settings all over again.
    If you wanted a macro as well you could go for
    http://item.mobileweb.ebay.co.uk/viewitem?sbk=1&nav=SEARCH&itemId=310725249995
    With regards to flashes I use sb910s but I've used the 600s as well and they are excellent
  18. Xir
    Xir Modder
    26 Apr 2006
    Hence the popularity of the 35mm f1.8...scales to a "nifty fifty" on your camera.
    I've got the SB200...it's really tiny, way better than the built in one, and of course swivels to the ceiling.
  19. sotu1
    sotu1 Ex-Modder
    24 Aug 2007
    My understanding was that the 50 was nifty because of the quality it produces at the price, and less to do with the focal length?
  20. hughwi
    hughwi Minimodder
    23 Dec 2003
    This is what I bought, and really havent looked back, apart from an ultra wideangle on a cropped body.
