Electronics What lines in the serial port
Discussion in 'Modding' started by Phire, 19 Sep 2002.
  1. Phire
    Phire Performance-PCs.com
    11 Jan 2002
    Which pins on the serial port carry the 5v line? Like I wanna wire a 3 pin vfd display to a serial port and use a serial to usb adaptor to clean things up......
    If the serial doesnt have a 5v line and gnd then how could I utilize the 5v on the usb and the data lines with a serial display?
    Thanks!
    -D
  2. Drastik
    Drastik What's a Dremel?
    10 Jan 2002
    i dont think there is a +5volt in serial if tehre is i am sure it cant handle it because my usb porn cant handle my bg micro vfd
  3. Phire
    11 Jan 2002
    really? I heard that the usb could handle the vfd......somehting like it draws 700ma max and the port gives off 500ma but it still works.....:(
  4. Meblin
    Meblin Supposed IR God!
    5 Mar 2002
    The ground is pin 5 and the voltage supply is pin 1 (think it's 5V)
    Meblin
  5. Drastik
    10 Jan 2002
    well like u said it handle 500 but the lcd oulls 700 and it blew my usb header
  6. AmPz
    AmPz What's a Dremel?
    27 Jun 2002
    Meblin: Wrong.
    Ground is pin 5, but there is NO supply pin on the serial port.
  7. Meblin
    5 Mar 2002
    OOPPSSS :lol:
    Code:
    Name        25-pin         9-pin
    TxD           2             3       transmit data
    RxD           3             2       receive data
    RTS           4             7       request to send (here: power source)
    CTS           5             8       clear to send
    DSR           6             6       data set ready
    GND           7             5       ground
    DCD           8             1       data carrier detect (here: signal line)
    DTR          20             4       data terminal ready
    There you go :)
    Meblin
  8. FuzzyOne
    FuzzyOne
    19 Sep 2002
    Ive got my Winamp box powered off the serial port but I can't remeber what pins tho.
  9. x24
    x24 What's a Dremel?
    9 May 2002
    Seconding the motion, pin7 is +5v.
    Meblin, the IR receiver worked :D
  10. AmPz
    27 Jun 2002
    There is NO +5V power supply line at all in the serial port! Gee...
    Some devices abuse the signal lines for power (about 10V, can deliver 1-5mA)
  11. cpemma
    cpemma Ecky thump
    27 Nov 2001
    AmPZ is quite right. See here
    Same goes for the parallel port. :nono:
