Other what mouse do you guys use?
Discussion in 'Hardware' started by jamesn, 6 Mar 2013.
  1. monteur
    monteur What's a Dremel?
    11 Apr 2011
    Had the G5 and it was lovely, must have dropped it to often of the desk and it died. Since then i've been scrubbing my pad with the mx518 and now i'm tending to the G400 although the mx518 is still fine it could be just little bit more arched.. perhaps i'll just close my eyes and yell "take my money" and treat myself with the G700 :D
  2. Sloth
    Sloth #yolo #swag
    29 Nov 2006
    Mad Catz R.A.T. 7
    Got it set up to be extremely comfortable. Good smooth scroll on the middle wheel with tactile clicks, soft side buttons are quick and easy to press, and the right click is the best of any mouse I've used. Very sensitive and allows for quick repeated clicks.
    Only complaint about the design, the aluminum frame is extremely sturdy but the added weight can make small movements lack a bit of precision.
  3. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    I have for that I use as I change them now and then.
    Logitech G9x best software ever
    Cooler master sentinel awesome combination software and feel
    Corsair M65 aloud feeling mouse
    Cooler master storm my favorite gaming mouse.
  4. RagingMadman
    RagingMadman What's a Dremel?
    6 Oct 2012
    Rat 7
    I'ts ****ing beautiful
  5. moose67
    moose67 Minimodder
    22 Nov 2009
    Been using a G9 for a good few years now and can't fault them at all, except the price of course. :hehe:
  6. lilgoth89
    lilgoth89 Captin Calliope
    12 Mar 2011
    im using the Roccat Kone+ fits my hand very well, is nicely wighted and glides quite nicely, the only issue is after owning it for a year, the pads are wearing out on the underside, and I cant find anywhere that stocks replacements >_<
  7. Cei
    Cei pew pew pew
    22 Mar 2008
    Razer Mamba v1 in wired mode.
    Used to own an MX518 until the covering all peeled off.
  8. Marvin-HHGTTG
    Marvin-HHGTTG CTRL + SHIFT + ESC
    10 Oct 2010
    I started off with an MX518 until I fancied a couple more buttons. So I moved to the G700, which I loved everything about apart from the tracking seemed strange at the time (as it turns out, I had the DPI set low and the sensitivity set high, where it should really be the other way around).
    I had a Deathadder, which was comfy but the finish was annoying, the chance of failure with Razer mice seems high and I still wanted some more buttons on the side.
    Enter the Roccat Kone[+] - probably joint best mouse I've ever used, material, size, features and comfort, plus good software and customisability. Unfortunately, the button layout meant the extra buttons were not in a good location to press for me.
    So, I went for the Naga. What a PoS. I loved it while it worked, but within 4 months the scroll wheel no longer registered in one direction, plus being a Razer it felt like cheap tat. And so it proved.
    After this, I had got used to the extra side buttons (using one for push to talk in Mumble, and then mapping loads of commands to it for each and any game I played), so thought I'd try the R.A.T. series, especially as they'd just released an MMO varient.
    All I can say is that I hope the other R.A.T mice are better. The side button fell off after a month or two, the plastic wasn't great feeling, and the "aluminium chassis" was actually slightly warped, so that if you left clicked, the mouse rocked, moving the cursor.
    Anyway, got rid of that, and thought I'd try the Logitech G500, which I'd looked at when I bought the G700 and then forgot about. Damn, I could have saved a lot of money. It cost £30, and is the best mouse I've ever had. Excellent shape, size and side button placing (3 of them as well! So I can have one permanently push to talk while the others are back/forward for the browser), hyperscroll - the best feature ever - side scrolling (which can also be remapped as buttons in games), plus a nice easy DPI adjust.
    I also have the Performance MX for travel use and it's fantastic (though the sensitivity is too low for gaming now that I'm used to higher), with probably the best shape I've ever tried.
    Basically, there's only one mouse I'd like to try now, and that's the Mionix Naos 5000, but I'd hate to lose that extra side button...
    Oh, and,
    Kustom PC
  9. Yslen
    Yslen Lord of the Twenty-Seventh Circle
    3 Mar 2010
    Just got myself a R.A.T. 5 based on the recommendations for the 7 here, which was more than I could afford. The 5 is lovely, very good fit for my hand thanks to the adjustable palm rest. Build quality is really nice and solid, and the click action is really (really) good.
  10. Elton
    23 Jan 2009
    And old MX518 and a Steelseries Ikari.
    The Ikari is a wonderful mouse, but for only right handers. The Naos 3200 and the Ikari share the same body shape.
  11. lilgoth89
    12 Mar 2011
    snip
    Kiitos Mr Marvin
  12. TheP
    TheP What's a Dremel?
    9 Oct 2012
    Logitech G600
    Tested some MMORPG mice so far and this one is in my oppinion the best,after you get used to the fact there is a third button under your ring-finger.
  13. Gunsmith
    Gunsmith Maximum Win
    23 Sep 2005
    MX Performance
    I don't need gimmicks to improve my game.
  14. MjFrosty
    MjFrosty What's a Dremel?
    3 Aug 2011
    Roccat Kone Pure. Had the Kone+ previously and it's a bit of a brick. Much prefer this, in fact probably the best mouse I've had in a long run of mice. I went through three Logitech G5s once upon a time through bad temperament. :blush:
  15. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    MX Revolution. It works for me.
  16. KeTZz
    KeTZz Minimodder
    25 Apr 2009
    Razer DeathAdder Black Edition all the way :rock: and i mite add picked one up for £30 quid because of a price error on the website :thumb:
  17. MightyBenihana
    MightyBenihana Do or do not, there is no try
    8 Sep 2011
    MX 518 - does all I need it to and is very comfortable.
  18. NethLyn
    NethLyn Minimodder
    24 Apr 2009
    Targus are best known for their teeny tiny laptop mice but their full size wired one isn't bad either for less than a tenner (online only from Argos or Amazon);
    http://www.amazon.co.uk/Optical-Mou...OU/ref=sr_1_24?ie=UTF8&qid=1338471318&sr=8-24
    That picture is rubbish though, the one I received looks exactly like the wireless version.
    Great handling for everything including games, it's a large-hander's dream (ie if you were comfortable with the original Xbox pad size of large). I took a chance on it unseen and it paid off but agree that you need to handle a mouse if you're spending big money, PC World and Maplin are still good for something!
