Build Advice What Next!
Discussion in 'Hardware' started by Uggers, 24 Jul 2013.
  1. Uggers
    Uggers What's a Dremel?
    17 May 2009
    So long story short, I'm not to sure what to upgrade on my Rig next.
    The spec at the moment is;
    Intel Core i5 2500K @ 4.4GHZ
    MSI P67A-GD53
    EVGA 670 Cheesecake Signature2
    ASUS Xonar D2X Audio Device
    x8 GB of Corsair RAM
    I'm happy with my storage, case, monitor, keyboard etc
    I am wondering if I should wait for the Haswell-E processors (8 cores I think?) and just save up till then as I'd need a new CPU, Mobo and Ram?
    Any thoughts?
  2. flame696
    flame696 Terminating People Since 1980....
    15 May 2009
    To be honest your rig is fine as it is no need to upgrade. It's got the the CPU and GPU power that you will need.
    Do you have a SSD?
  3. djzic
    djzic Bokehlicious!
    8 Nov 2010
    You could always get a second GPU? Two 670s best a Titan. Otherwise if you have enough GPU power, and you don't have an SSD, it's a wise upgrade.
  4. Bladesingerz
    Bladesingerz Minimodder
    30 Nov 2011
    As mentioned above, an SSD would be the best choise.
  5. Uggers
    17 May 2009
    Sorry forgot to say, I've got 1 Crucial M4 120GB and 1 Vertex 60GB SSD :)
    and thats good to know :)
