What OCZ-Ram to choose?
Discussion in 'Hardware' started by PA!N, 5 Oct 2005.
  1. PA!N
    PA!N What's a Dremel?
    16 Jul 2005
    Hi Guys I need some help again,please:
    I want to buy 2 gig OCZ Ram but i duno which to choose!
    So my supliers sells DIMM 2 GB DDR-400 Kit
    "Value"
    for 229€
    ( no heatspreader)
    And DIMM 2 GB DDR-400 Kit
    OCZ4002048PFDC, Performance, 512 MBit
    for 239€
    (copper color heatspreadder)
    And also DIMM 2 GB DDR-400 Kit
    OCZ4002048ELDCPC, Platinum EL
    for 259€!
    (platinum color heatspeadder)
    So my question is, if there is any "big" difference
    eccept the color of the heatspreadder?
    (they all theme to have the same cas latency)
    I dont want to overclock the RAM so which would you suggest m8's?
    Thanks in advance
