Linux What OS for a media computer?
Discussion in 'Software' started by The cheapskate, 30 Dec 2007.
  1. The cheapskate
    The cheapskate One custom title before Matty
    27 Oct 2004
    Gent's,
    I'm looking for a Linux distro designed for a media computer.
    However My Linux knowledge isn't good and certainly isn't up to date. Does any one have any good experiences with Linux based media centers?
    As in what Distro do you recommend, I really need a decent front end for display on my tv. Similar to XP MCE, however I really want to avoid paying for an MS license key, and would like to expand my knowledge.
    any input welcome on the best way to do this?
    E-beer for all decent responses!
  2. ryanjleng
    ryanjleng ...
    15 Nov 2007
  3. Glider
    Glider /dev/null
    2 Aug 2005
    Posting illegal stuff will get you banned... and it's not the first time you do so... /REPORTED
    Now, MythTV is a frontend for about every distro, Gentoo has it, Ubuntu has it... It's not that easy to setup, but there are plenty of guides around that help you with setting it up for your favorite distro.
  4. lamboman
    lamboman What's a Dremel?
    25 Jul 2006
    If you know that you aren't allowed to quote illegal stuff, why do you do it? You deserve the mods to kick your backside. You can do it in your own time, but don't get others into it.
    On topic, as Glider said :D
  5. specofdust
    specofdust Banned
    26 Feb 2005
    No need to be asshats guys. If he's done something wrong the mods will get it. Not that it surprises me that a massively pro-linux person would be anti-MS-copying...
    +1 for MCE with Ubuntu and a step-by-step guide. Get it going, then don't touch it.
  6. Guest-16
    Guest-16 Guest
    48hr ban for posting warez, vr.
  7. The cheapskate
    27 Oct 2004
    Glider,
    So myth TV isn't an actual linux distro, I thought it was a bit small for a full OS!, What do you recommend as an easy distro to setup for use with myth tv?
    /also can we keep things on topic? I know about the other options, however this is a learning process as well and I would like to give Linux a shot.
    any way cheers for the responses so far.:thumb:
  8. specofdust
    specofdust Banned
    26 Feb 2005
    Regarding easy distro's, stick with ones that are easy for everything, not just myth. My advice would be find a guide that will tell you how to do _everything_ - know how to do the entire thing before you've even done it, and then when you actually do the install you'll only have to spend a few hours searching around fixing issues :p
    My 2 penneth would go to Ubuntu, or Fedora (since there were some superb guides for fedora floating about last year). The ubernoob disrto's probably don't offer any benefit over and above the standard nix-noob ones like ubuntu, so stick with the latter (they tend to be more customisable, have larger communities, and have communities that know stuff - possibily with the exception of ubuntu).
  9. ryanjleng
    ryanjleng ...
    15 Nov 2007
    i meant KnoppMyth earlier.
    it's Linux with MythTv built as one.
  10. specofdust
    specofdust Banned
    26 Feb 2005
    IIRC while KnoppMyth is slightly easier to get going, it's not nearly as customisable. Perhaps not an issue for everyone, but one to consider nonetheless.
  11. The cheapskate
    27 Oct 2004
    Cheers Guys. As customization isn't something I'm to worried about, I am now downloading KnoppMythm and will run the install over the weekend. which should make in interesting Friday night :D
    any one know of any good guides for this distro of Linux? and im hoping it does have gui based installer, or at least something that is easy to follow?
    I will keep you up to date. - so far specofdust, ryanjleng & Glider I owe you one, cheers guys.
  12. adam197
    adam197 What's a Dremel?
    22 Feb 2005
    Keeping an eye on this as it sounds like what I have planned within the next few months.
  13. Glider
    Glider /dev/null
    2 Aug 2005
  14. The cheapskate
    27 Oct 2004
    You sir, are a legend. :thumb:
    any other thoughts about this people?
