Evening all. I'm looking at building a htpc out of some old pc parts. It will be basically to store and watch all of videos own and able to fit a 4k bluray player. Now my question is what os would be suitable?
Pingu of Personal Preference would probably be the best option then slapping plex or kodi atop it [though upon reflection i think both prefer you be on ubuntu]. Not sure what the state of Blurry playback on linux is though, DRM and all that bollockry. Though if you're ripping creating personal backups of the disks iirc it's less of an issue. @Gareth Halfacree might know.
Yeah, I'd say Ubuntu with Plex or Kodi on top is yer best. Not sure about Blu-ray, though, as I never bothered on the desktop - I've only got a DVD-RW drive in that. I had an Acer laptop with a Blu-ray drive, but that was my dedicated Windows box. Running Vista, to give you an idea of how long ago that was!
Not an answer as such but (as somebody who swore by htpc's since 2001) getting everything to work nicely and pass the WAF (i.e. needs to all be on a remote control) I've found sticking plex on a "server" for my media then using an Xbox One with plex installed works. Gives you access to your digital media and had the bluray drive you need built in.
Depends how you want to control it, I just use a wireless keyboard/mouse combo so just have windows, means I can play games, use a web browser etc easily if I want. Have a BR drive in it and just use a free player that I can't remember the name of at the moment but yeah. Used to have a plex setup, but found it more hassle than it was worth for my needs/wants.
This. Streaming boxes/dongles like a Fire TV Stick are a much cheaper front-end for Plex, although you'll lose the ability to play bluray discs. As soon as I got an Nvidia Shield a couple of years ago I gave up on the idea of having an HTPC. If you really really want an HTPC then my money would go to Kodi, or a Kodi-based distribution like OpenElec or similar. But you won't get access to any streaming services, not even YouTube is 100% reliable AFAIK.
