What P35 boards are good overclockers?
Discussion in 'Hardware' started by Yotta, 11 Mar 2008.
  1. Yotta
    Yotta Minimodder
    10 Mar 2008
    Hi
    Apologies if this is in the wrong place, I'm new round here.
    Looking to build a gaming rig and possible a dabble at overclocking. Any recommendations for a good P35 775 motherboard would be a great start.
    A board that has raid support without needing a separate controller would be good.
    Thanks
  2. DaveVader
    DaveVader Fast Action Response Team
    10 Aug 2007
    I'm going to be ordering a Gigabyte GA-P35-DS3R in a couple of weeks, it's cheap (very cheap for what it is) has many SATA ports and practically everything I want. I hear the overclocking is pretty decent, search for it on here for a good review. I may post how well mine does aswell.
  3. Yotta
    Yotta Minimodder
    10 Mar 2008
    Will go and read a few reviews on that board now. Thanks :)
  4. nigelleg
    nigelleg What's a Dremel?
    4 Jan 2008
    I wish I had spent the extra 50 quid and gone for that board it was one of the boards I originally looked at, saved the money on the board so I could get the 8800gt dont know if it was wise now as it does not look like i have any overclocking options on my board
    I look forward to your post on the board
  5. DaveVader
    10 Aug 2007
    Yeah I can't wait to switch to Intel, I've read quite a bit about the board and it is deffinitely value for money and I try and do everything as cheaply as possible. I'm going for the E8400 aswell so I will see how well the 2 work together
  6. Yotta
    Yotta Minimodder
    10 Mar 2008
    You must have got the DP35DP for a bargain price if it was £50 cheaper than a GA-P35-DS3R. Just looked at prices for the DP35DP and they are up around the £70 mark.
  7. mushky
    mushky gimme snails
    24 Mar 2003
    DS3R - Great board if you don't want to use S3 standby.
  8. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    all of them
  9. Yotta
    Yotta Minimodder
    10 Mar 2008
    Does anyone know what bios version the GA-P35-DS3R is likely to come with if it's new stock? I'm not hugely confident when it comes to bios flashing.
  10. Yotta
    Yotta Minimodder
    10 Mar 2008
    Apparently not according to nigelleg's earlier reply.
  11. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    I'm looking to Gigabyte for my next mobo as well.
    You may want to look at the newer EP35-DS3R, as the power-saving features designed into it are specifically designed for Wolfdale (E8xxx) CPUs.
    It's only an extra fiver too. :thumb:
  12. airchie
    airchie What's a Dremel?
    22 Mar 2005
    Isn't the abit IP35 board a good OCer?
    And isn't there a -E model that's cheaper but equally good for OCing?
    Not 100% sure, just seem to remember reading it somewhere. :)
  13. nigelleg
    4 Jan 2008
    paid R1050 for the intel board which is about 68 quid
    DS3R board was about R1900 about 125 quid
    checked price now its still R1913 so price has not changed here over last couple of months at todays rate thats about 120 quid
    How much is the board there? I know the answer will break my heart .. just like the 50 quid we pay here for an arctic pro 7 cooler thats about 15 quid over there
  14. DaveVader
    10 Aug 2007
    it's a few pence over £70 on Scan so ... a lot cheaper.
    and cheers IanW I will look into that.
  15. nigelleg
    4 Jan 2008
    Dont have the E here yet this board below is about 12 quid more here has DDR2 and DDR3 slots but I dont know if its any good first time I saw it
    Gigabyte GA-P35C-DS3R IP35 Motherboard w/A8 + LK + SATA2 RAID
    [GA-P35C-DS3R]
    GIGABYTE® "S Series" P35 & ICH9R Express Chipset - Socket LGA775 @ FSB1333 - For Pentium®, Pentium®D & Core™2 Duo & Quad
    Memory Graphics
    DDR3-1333 | DDR3-1066 | DDR2-1066 | DDR2-800 | DDR2-667 PCI Express | PCI
    Supports Intel® Core™ 2 multi-core and upcoming 45nm processors
    Supports both DDR2 and DDR3 memory for great flexibility
    Features PCI Express x16 for outstanding graphics performance
    Integrated SATA 3Gb/s with RAID function
    Features high speed Gigabit Ethernet
    Ultra Durable 2 motherboard design
    Japanese manufactured solid capacitors
    Audio controller from ALC 889A supporting for both Blu-ray and HD DVD formats
  16. Yotta
    Yotta Minimodder
    10 Mar 2008
    I've added it to the possible list, along with airchie's abit suggestion. Thanks.
  17. DaveVader
    10 Aug 2007
    yeah, IanW swayed me to get that bored
    £235 for my next upgrade isn't too bad, New motherboard, CPU and HSF.
  18. Yotta
    Yotta Minimodder
    10 Mar 2008
    Is it likely to be a wasted call if I phoned Scan to enquire about what bios version new stock of GA-P35-DS3R is shipped with?
  19. mushky
    mushky gimme snails
    24 Mar 2003
    EP35 has 8 usb ports on the back too :) Missing the serial and parralel ports to make space.
    I'd be really happy with mine if it wasn't for the S3 standby problem (hopefully sorted with a BIOS at some point) and the fact that it doesn't do DTS connect or DD live onboard, even though it has the hardware for DTS connect. Gigabyte skimped on the license for this "budget" board.
  20. BUFF
    BUFF What's a Dremel?
    25 Mar 2005
    yes, & they are both under £60 on SCAN Today Only today - £59 for a board with ICH9R & firewire is hard to beat & it does 500fsb plus ...
