Electronics what "package" should I get when I buy PICs?
Discussion in 'Modding' started by Twyst, 16 Nov 2004.
  1. Twyst
    Twyst What's a Dremel?
    9 Dec 2002
    I've just bought myself a PIC programmer (a PIC16PRO), from EBay, so I can start some of the more interesting projects - like Propeller clocks, etc.
    Now, I can buy PICs locally, but the electronics supply store I go to has 4 or 5 different versions of each. So I'm confused. Do I want PDIP, SSOP, SOIC? What's the difference?
  2. The Bodger
    The Bodger What's a Dremel?
    26 Dec 2003
    The package is the size / appearance of the chip. You can get the PIC in surface mount (small and fiddly) versions and larger versions with through-hole mounting legs. The latter is what you want. Therefore you should get the PDIP version. If you want to see the differences, see below:
    Hope this helps! (edited to fix picture :blush:)
  3. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    look where? :p
  4. Twyst
    9 Dec 2002
    Wonderful! Now I know. :D
  5. Hazer
    Hazer In time,you too will be relixalated
    14 Apr 2003
    On further note: The place you get these from, are these PIC16Fxxx or PIC16Cxxx chips? You dont want the PIC16Cxxx chips. These require a UV light to erase them.
    As for which chips, here are a few more common ones that are best for beginning:
    16F872/F874/F876/F877/F876A/F877A
    16F88 (dont bother with the 16F84, its outdated and the F88 is the same price).
    16F676
    These chips tend to produce more results when googling for example code for specific peripherals.
  6. Twyst
    9 Dec 2002
    Well, I *was* going to buy them locally.. But then I found out they wanted $11 per 16F84A. Yuck. If I can find them for less than that online, I'll be a happy camper.
  7. H2O-G33K
    H2O-G33K What's a Dremel?
    25 Jan 2003
    You can get samples from Microchip.com - up to 15 per month, although I suspect if you keep ordering lots of them, theyll start asking questions :)
