What programs do you use for PHP programming?
Discussion in 'Hardware' started by jezmck, 25 Sep 2005.
What do you use?
  1. Notepad (or similar)
    47.1%
  2. Dreamweaver (or similar)
    26.5%
  3. Eclipse (or similar IDE)
    2.9%
  4. Zend Studio
    14.7%
  5. Other
    29.4%
Multiple votes are allowed.
  1. jezmck
    jezmck Minimodder
    25 Sep 2003
    ATM, I just use Dreamweaver so I can upload my files most easily, and because it does code-colouring; but I have been wondering if I'd be better off using an Eclipse plugin or something.
    (I should probably install Apache too, so I don't have to upload files to test!)
    What do you use?
  2. RTT
    RTT #parp
    12 Mar 2001
    Zend Studio. By the same people who 'do' php and is available for Windows, Linux and Mac.
    (and added to the poll for good measure)
  3. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    Dreamweaver here :) I like the way your Fireworks designs go straight into it without any problems.
  4. [Jonny]
    [Jonny] What's a Dremel?
    1 Sep 2003
  5. jezmck
    jezmck Minimodder
    25 Sep 2003
    will def have a look, and thanks for the addition - makes a more useful poll :)
  6. Nath
    Nath Your appeal has already been filed.
    28 Dec 2003
  7. hitman012
    hitman012 Minimodder
    6 May 2005
  8. SJH
    SJH Minimodder
    24 Dec 2003
    EditPlus, does the whole lot: PHP, (X)HTML, CSS, JavaScript, etc...
  9. hacker 8991
    hacker 8991 What's a Dremel?
    8 Jan 2004
  10. Firehed
    15 Feb 2004
    Notepad. Not providing a link. If you can't find it... well... let's hope you can.
    Of course, my PHP is VERY basic. But it makes the page work how I need. I do all my web coding in notepad though, be it html, php, js, css/related or... well that's all I really do. Most of my original work is plain HTML, a lot of the rest is just tweaking free code (phpbb, menu scripts). I think my only original php work is just using the page.php?thing=somethingelse to load somethingelse.txt into the page. But like I said, it gets the job done.
    I should get something that does coloring of sorts though. I did all my old C work with Dev-C++ which colorcodes to a limited extent, but as soon as I save as something other than c/cpp/h etc, it stops coloring :(
  11. tuteja1986
    tuteja1986 What's a Dremel?
    25 Sep 2005
    editplus 2 but i am not a fan of PHP since it takes longer to do than plain good old XHTML 1.0 strict + CSS + javascript. err i am lazy :(
  12. jezmck
    jezmck Minimodder
    25 Sep 2003
    I'm just starting to do more advanced PHP, including more DB interaction, and need something more robust and up to date than my current version of Dreamweaver.
    Thanks for the replies everyone - I will be looking at those this morning.
  13. Go4t
    Go4t i
    13 Dec 2003
    Vim, nano, occasionally Dreamweaver, Macromedia Homesite, Bluefish, and SubEthaEdit on my mac at work.
  14. simon w
    simon w What's a Dremel?
    3 Nov 2003
    Just started using Zend 5 beta, but also frequently use Kate and vi
  15. _Fathom17_
    _Fathom17_ What's a Dremel?
    20 Sep 2005
    cant believe people still use vi!
  16. eek
    eek CAMRA ***.
    23 Jan 2002
    always use scite tbh!
    I wrote my 3rd year project (almost 8k lines of code) in it without a hitch!
    I just like to have something light which can do colour coding, most other features that other progs advertise arnt really of much interest to me!
  17. theurgy
    theurgy What's a Dremel?
    8 Oct 2004
  18. ch424
    ch424 Design Warrior
    26 May 2004
    I use metapad on windows, and gedit on Linux. gedit is awesome: it can colour-code anything.
    ch424
  19. simon w
    3 Nov 2003
    I only use it when I'm SSH'ed into a server and there isn't much choice. However most of the ~30 other developers at work use vi all day, every day...
  20. doryakov
    doryakov What's a Dremel?
    8 Aug 2005
    notepad its the simple program
