PSU What PSU can I get away with?
Discussion in 'Hardware' started by ch424, 19 May 2009.
  1. ch424
    ch424 Design Warrior
    26 May 2004
    Hi everyone
    I've had a Tagan TG480-U01 for 4 or 5 years now, and while it works absolutely fine, I do have some objections to it:
    1. The PCIe cables have a weird ferrite bead on the end and way too much heatshrink, meaning I can't bend them out of the way and I effectively lose 3 hard disk spaces in my case.
    2. It gets noisy under full load, and makes my case vibrate at an irritating frequency.
    3. I think it's limiting my overclocks. I've not been able to make my Q6600 go any faster than 3GHz with either my P5QL-E or a Gigabyte EP31-DS3L, despite relaxing memory timings, lowering the multiplier, turning off C1E, raising NB voltage etc.
    4. My computer is the most power-hungry thing in my room at uni and my bill was £20 last term. The tagan is apparently 70% efficient, so getting a nice 85% one should mean a new PSU subsidises itself over a couple of years.
    My spec is:
    ASUS P5QL-E mobo
    Q6600 currently at 334x9=3GHz and 1.3V
    2x2GB of OCZ platinum stuff at 2.1V
    HD4850 not overclocked
    DVD-RW drive
    2x 1TB Samsung F1s
    1x 250GB Samsung old SATA drive
    Floppy drive/card reader combo
    3x 120mm fans
    The eXtreme PSU calculator says I need about 400W, but given my overclocking problems and the way my 480W one speeds the fans right up, I'm not convinced.
    So, my question is: What power supply should I get? 500W? 600W? Brand and model?
    I presume that most of the time, the system is only using 150-200W and it only goes right up to 400/500W when I'm encoding videos or playing games. It would therefore be good to get a PSU that's really efficient at 50% too. I'd like 83%+ ideally.
    Finally, I don't really want to spend more than £75, and closer to £50 would be much better. I'm considering getting the 700W FSP one from scan that's actually really good despite being £35, but it may have cables that are far too short.
    Anyway, thanks for any help!
    ch424
  2. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    400-500W will be fine.
    Didn't the OCZ ModXStreams have a high efficiency? Take a look at them.
    ch424 likes this.
  3. Joekerh
    Joekerh Penniless enthusiast
    1 Mar 2009
  4. jbloggs
    jbloggs What's a Dremel?
    12 Sep 2007
  5. Joekerh
    1 Mar 2009
    Unless you are planning on going for crossfire in the future... jbloggs suggestion would indeed be better and save you some money.
  6. skybarge
    skybarge just chilling at work
    29 Feb 2008
    Yeah got the Corsair 450w or the Silverstone 500w 80+ efficiency, it'll run fine :)
    even slap a 4870 onto that and it'll still be ok
    trig likes this.
  7. RinSewand
    RinSewand What's a Dremel?
    11 Sep 2006
    Another vote for the corsair - I've got a Tagan 480, and a Corsair 550, and would always reccomend the corsair - both on heat produced, and sound. The cables are also a lot easier to manage!
    RwD
  8. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    the vx550 is only 10 bucks more looks like on scan.. nothing wrong with having a bigger supply than needed- especially if it's that close in price
    end of the year is when to buy these things though.. can usually get some sweet deals
    ch424 likes this.
  9. ch424
    26 May 2004
    Thanks for all the suggestions everyone. I think I'll wait for a bit for the prices to come down. Enermax do some 86%+ units, yet nobody has recommended them - is there something wrong with them?
  10. trig
    trig god's little mistake
    10 Aug 2006
    price for the unit...enermax is proud of their psu's...
    ch424 likes this.
  11. bagman
    bagman Minimodder
    18 Apr 2009
    i wouldn't it is a rip off
    look at this silverpower 500w http://www.scan.co.uk/Products/500w...er-80-Plus-CertifiedIntel-ATX-12V-6Serial-ATA
    or if you have the money to spend
    http://www.scan.co.uk/Products/620W...CI-E-SATA-80plus-Eff-ATX-12V-V23-EPS-12V-V291 same price of corsair but an extra 100w which will come in handy when you upgrade to a high end card
  12. Cus_de_Sparta65
    Cus_de_Sparta65 "There is no dremel"
    24 Apr 2009
    This is the 3rd time I have pointed someone in the direction of this PSU, don't know if anyone has actually took my advice though. I think it is an absolute steal at this price. It is a "Antec 650W Neo-Power semi-modular" highly efficient (up to 85%)
    I got one a few weeks ago and as I had never used the company before I was a bit apprehensive about it. Well there was no need to be as it is a great PSU even at the R.R.P. and it arrived in 4 days, so quite quickly. They are asking for £59 but I put in a offer of £50 and they accepted it no problem. Maybe you can try £47 or even a bit lower, you never know but for even £50 it is a fantastic buy.
    http://tinyurl.com/r923pm
    Edit- I forgot to mention the one negative if you are in the UK- it does not come with a UK power cord, get one from the kettle or something
  13. Gooey_GUI
    Gooey_GUI Wanted: Red Shirts
    3 Dec 2002
    Corsair 620W - modular
    One of the best on the market. :rock:
    trig likes this.
  14. trig
    10 Aug 2006
    me owns....me lubs
