PSU What PSU for £100 or less
Discussion in 'Hardware' started by flame696, 9 Mar 2012.
  1. flame696
    flame696 Terminating People Since 1980....
    15 May 2009
    Hey another question by me, im looking to replace my ageing Antec Truepower 850w PSU. its given me 3+ yearsw of great service but its a lot bigger then the PSUs now available (180mm length) and its not fully modular. It was a pain to install in my tiny TJ08-E, what do you guys recommend i really would like it to be under £100. Was looking at the corsair AX850 but its £149!!!
  2. flame696
    15 May 2009
    no one? hmmmmm must be my budget i can go up a few ££s
  3. bdigital
    bdigital Is re-building his PC again
    10 Aug 2010
    mmMMmmm AX850 Gold :) 7 year warranty.
    EDIT: Although from memory its pretty big
  4. flame696
    15 May 2009
    lol :read: anything else?? there must be something
    edit:its only 160mm long where as mine is over 180mm long and in a TJ08-E makes a lot of difference
  5. faugusztin
    11 Aug 2008
  6. flame696
    15 May 2009
    hmmmmm i think you guys are on commision from corsair..... is 650w going to be enough if i want to sli my 580 or even get the kepler equivalent
  7. faugusztin
    11 Aug 2008
    Well, i initially planed to suggest you the Seasonic X, but it is at same or higher price level, while being pretty much the same (Corsair AX650,750 and 850 are made by Seasonic based on X-Series design).
    Seriously, there is nothing better on the market, the semi-passive mode, the ultrasilent operation of these power supplies, the long warranty. Buying this PSU is like buying a good IPS display - you will switch few computers while using the same PSU.
  8. flame696
    15 May 2009
    looks like ill have to go for the corsair AX850 then
  9. flame696
    15 May 2009
    hows the corsair TX Enthusiast range?? worth buying?
  10. AoE
    AoE What's a Dremel?
    4 Oct 2011
    i GOT A gs700 may be looking rid of to get a smaller psu, 7 weeks old
  11. flame696
    15 May 2009
    gs700?? got a link to specs?
  12. faugusztin
    11 Aug 2008
  13. flame696
    15 May 2009
    i should have mentioned im looking for a fully modular PSU
  14. faugusztin
    11 Aug 2008
    Well, then you are back to Seasonic X or Corsair AX.
  15. flame696
    15 May 2009
    damn it oh well corsair ax here i come
  16. jaypopat
    jaypopat What's a Dremel?
    23 Jul 2011
  17. MrTeal
    MrTeal Minimodder
    27 Aug 2010
  18. catsol75
    catsol75 What's a Dremel?
    2 Mar 2010
  19. xxxsonic1971
    xxxsonic1971 W.O.T xxxsonic1971
    5 Dec 2010
    i got an xfx 850w and its great, i think it has just 1 big 12v rail as well
  20. Big Elf
    23 Apr 2009
    If you're going for fully modular to sleeve it then the Silverstone Strider is the best one for that. It's the only one to have full ATX spec 1 to 1 cabling on the plugs. After saying that there's probably capacitors on the PCIE cable to help suppress ripple but you can remove them with apparently little loss in performance.
