PSU What PSU for this system
Discussion in 'Hardware' started by TheP, 12 Feb 2013.
  1. TheP
    TheP What's a Dremel?
    9 Oct 2012
    Well....I'm planning the get some new hardware(mostly gaming) .
    These are those little dudes I thought about:
    -EVGA GTX660 FT*W Signature2 3072MB
    -Intel Core i5 3570K PC1155
    -MB Gigabyte GA-Z77X-D3H
    -DDR3 8GB PC 1600 CL10 CORSAIR
    What will be the absolute minimum psu to use for these components?
    Should a 600 - 700W psu be fine?
    Thanks in advance
    TheP
  2. Guest-23315
    Guest-23315 Guest
    Something like a Corsair 500/600W should be fine
  3. Chris_Waddle
    Chris_Waddle Loving my new digital pinball machine
    26 Mar 2009
    There is a pretty good on-line PSU calculator which you can use here
    It's pretty good, but obviously it's not gospel.
    Without completing that, I would say a 600W would be more than enough for that system.
  4. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
  5. TheP
    9 Oct 2012
    Budget.....is still pending. Absolute 1000€..... but well, trying to as cheap as possible but still with good performance for the next few years (actual pc is now about 6 years old and needs a complete upgrade)...and just one graphics card.
    Thanks for the answers and the link.
    I will figure out something the next day
  6. TheP
    9 Oct 2012
    One more thing (not about psu but dont want to open an extra thread).
    The graphics card is about 24cm.....does it fit in any standard atx tower (midi or big) or do i need a extra-long tower.
    Many many questions ^^
    But this will be my first pc i will assemble all myself and before byuing something "wrong" i ask those who have more knowledge then me.
  7. atc95
    atc95 I have the upgrade bug!
    3 Dec 2012
    I would say 500w would be fine but to give yourself a bit of headroom go for 600w, so something like this or a bigger wattage version like this.
    It depends on what case you have as some have loads of room whereas others have drive cages in the way but with a standard atx case 24cm should be fine but I would check on the case manufacturers website.
  8. TheP
    9 Oct 2012
    Thanks alot.
    Well....then i will go through the pages.
    And will also go through some test-reviews for graphic cards .....I bet i will find better cards for the same price. I have there a feeling -.-
