***What PSU have 8 pin PCI-E?***
Discussion in 'Tech Support' started by Otis1337, 8 Mar 2008.
  1. Otis1337
    Otis1337 aka - Ripp3r
    28 Nov 2007
    i carnt seem to get hold of a PSU that has a 8 pin PCI-E connecter...
    its going to be for the 9800GX2 and it needs a 6+8pin to power it!
    any ideas!?
    Thx:thumb:
  2. Fishlock
    Fishlock .o0o.
    22 Nov 2004
    Pretty sure the modular range of the Corsair PSU's have it...
    Edit: Yes it does. Get the hx520w.
  3. Otis1337
    28 Nov 2007
  4. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    That looks kinda overpowered, but if you need it, get one.
    And this time I'll not start yelling out "that is not good" before reading some reviews... :p
  5. Guest-16
    Guest-16 Guest
    You could use a 500-600W for a single 9800 GX2 ;)
  6. Fishlock
    Fishlock .o0o.
    22 Nov 2004
  7. Otis1337
    28 Nov 2007
    none of the Corsair PSU you guys have sed has an PCI-E 8pin
    there for there no good.
    So Corsair wont be supporting the 9800GX2 anytime soon
  8. dragon2309
    dragon2309 techie
    28 Jul 2006
    what bit of
    didnt you read then.... im guessing the 5th line down must have been in white text or something when you read it huh?
    take a peek at the tech specs section - http://www.scan.co.uk/Products/ProductInfo.asp?WebProductID=603580
  9. AlexB
    AlexB Web Nerd and WC Addict
    22 Dec 2005
    Hiper's have them too
  10. tomshawn
    tomshawn What's a Dremel?
    7 Mar 2008
    If you have a Enermax you can buy additional cable with 6+2 pin for g cards.
  11. Fishlock
    Fishlock .o0o.
    22 Nov 2004
    :wallbash:
    Get a Corsair PSU.
  12. Squadexodus
    Squadexodus I got my cookie. What about you?
    5 Jan 2008
    So wait, you need an 8 pin for 9800Gx2?
    Well, its an excuse to get rid of mah rosewill. you guys dont seem to like that power supply...
  13. Guest-16
    Guest-16 Guest
    You shouldn't need an excuse to get rid of a Roswell PSU :p
    Yes, I've been told it requires an 8-pin + 6-pin.
  14. OdDBaLL_MoD
    OdDBaLL_MoD Always planning something...
    13 Sep 2004
    Well, thats wrong for a start. The earlier versions of the Corsairs don't have 8 pin PCI-E. But, the later version do. I have a HX520 and that has 2 PCI-E 6+2 Pin connectors. In other words, a standard PCI-E 6 pin connector, with an additional 2 pin connector that slides down the side of it.
  15. sars
    sars What's a Dremel?
    15 Mar 2008
  16. 123mccann
    123mccann What's a Dremel?
    16 Dec 2007
    Same with my Corsair HX620. :)
  17. Squadexodus
    5 Jan 2008
    Yes i do. Everythings plugged in and working, and i dont want it to not work if it goes south. I dont have a backup computer, both of them broke...
