Modding what psu?
Discussion in 'Modding' started by Alekin, 26 Sep 2002.
  1. Alekin
    Alekin Minimodder
    27 Aug 2002
    im building a pc, im gonna put a 1.3 duron in it cd burner, floppy etc, no cathodes or suchlike at the mo. just a boring pc, but i need a psu. i like the q-tech 550 watt that macro reviewed but i have heard from a few peeps that it has a mind of its own and turns off when ever it feels like it, and ive read somewhere that a few people have upgraded from a 400 to the 550 and it cant turn their pc's on. do any of you people know anything about it and if it is crap can u reccomend another psu?
    cheers
    alex
  2. m00min
    m00min What's a Dremel?
    6 Jul 2002
    you should happily get away with using a box standard 300w PSU if you want more buy any AMD "Recommended" 400w PSU, no need for a 550W PSU man !
  3. Alekin
    Alekin Minimodder
    27 Aug 2002
    yeah, i know i dont need a 550, but i like the look and cant find a lower wattage one, but im thinking of putting a job lot of cathodes in it so in the long run a 550 might be useful??
  4. Moo
    Moo What's a Dremel?
    19 Aug 2002
    Cathodes don't draw much power but they do give off some electrical interferance. (Don't plug one into the spare molex on your hard drive power lead.) I would look at getting a lower powered PSU, but one from a good quality company like Antec.
    Tech Report have a review at http://tech-report.com/reviews/2002q3/psus/index.x?pg=1
  5. NiHiLiST
    NiHiLiST New-born car whore
    18 Aug 2001
  6. bAnTAi
    bAnTAi What's a Dremel?
    19 May 2002
    550W for a bog standard? Crazy:eeek: I have a 430 w/ many drives, cathodes, baybus etc 300 tops
  7. Adam
    Adam Minimodder
    26 Jan 2002
    When I do upgrades for people based on the 1.2 Duron, single hard drive, CDROM etc I usually get the Nokia style case for £20. The PSU that comes with that has caused me no problems so I would say pretty much any supply is ok.
    Although, if you are thinking of upgrading in the future I can thoroughly recommend the Q-tec. I have had no problems, it looks great, and my voltages are spot on.
  8. Alekin
    Alekin Minimodder
    27 Aug 2002
    Maybe my stupid way of explanin things has confused u lot, sorry. The only reason i want the psu is coz i like the gold case and the red fans, on the q-tech site they have lower wattage ones but from what i can see you cant buy off it, and i cant find anywhere that sells the lower wattage ones
  9. Adam
    Adam Minimodder
    26 Jan 2002
    Seems a little pointless getting a lower wattage when the 550 is only £30. Just get that.
  10. Alekin
    Alekin Minimodder
    27 Aug 2002
    that was my thought all along but im too stupid to explain it clearly enough
    cheers dude
    alex
  11. bAnTAi
    19 May 2002
    is that all it is? for a cool 550W PSU? what have you got to lose? go w/ it....i might....
