PSU What PSU ?
Discussion in 'Hardware' started by Swanny, 23 Nov 2012.
  1. Swanny
    Swanny What's a Dremel?
    23 Nov 2012
    Hi all
    My first post.
    I have just ordered my new internals for a gaming PC i am builing. i have built office Pc's before and have just used 450W PSU's but this is my first Gaming PC.
    I have put a list of the components i am going to be using but am unsure as what size PSU to use.
    I was thinking of a Corsair TX750w, but i have heard that if the PSU isn't large enough it tends to fry things.
    I have read the Graphics card and CPU cooler i am planning on using are large power users.
    My PC spec was inspired by the DEC issue of Custom PC AMD article. I do love AMD but once the sandy bridge came out they seem to of fell behind until recently.
    anyway here is the list, would a 750w be good enough all advice and opinions welcome.
    [U]Proc[/U]
    AMD FX-8350 4GHz Socket AM3+ 16MB black edition
    MOBO
    Asus Crosshair V Formula AM3+ AMD 990FX SB950 DDR3
    Proc Cooling
    Corsair Hydro Series H100 High Performance
    G/card
    Gigabyte ATI Radeon 7950 HD 800MHz 3GB PCI-E HDMI Windforce 3X OC
    RAM
    Corsair 32GB DDR3 1866MHz Vengeance Memory
    SSD
    OCZ 120GB Agility 3 SSD
    2nd HD
    Seagate 2TB Barracuda Internal Hard Drive
    I am NOT planning on overclocking anything either, in case that makes a difference
    Thank you for reading, sorry if its a bit mix and match,
    Swanny
  2. ShinyAli
    ShinyAli What's a Dremel?
    14 Sep 2012
  3. Swanny
    23 Nov 2012
    Thank you will take a look now.
    Swanny
  4. Somer_Himpson
    Somer_Himpson What's a Dremel?
    22 Jan 2010
  5. mrbungle
    20 Sep 2004
    Did I miss something?
    On a more serious note the TX750 is more than up to the job.
  6. sniperdude
    sniperdude Minimodder
    8 Sep 2010
  7. ShinyAli
    14 Sep 2012
  8. jakobfrimmel
    jakobfrimmel What's a Dremel?
    2 Jan 2011
    i have a TX850 thats got more than enough for that rig and future up grades and is dead silent so i can recomend that!
  9. hamza_tm
    hamza_tm Modder
    10 Apr 2012
    550W will suffice from what I can see.
    750 is more than enough. The Be Quiet mentioned above is a great choice.
  10. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    550W is plenty as others have said. If you're planning to get a second card for CrossFire, you might want a 650-750W though.
  11. Xtheblackfox
    Xtheblackfox What's a Dremel?
    28 Nov 2012
    I would recommend 500W PC Power & Cooling Silencer Mk III
  12. Xtheblackfox
    28 Nov 2012
    Its a great psu, and can be found on scans wesbite. New to the forum, can i mention scan?
