Watercooling What pumps to get?
Discussion in 'Hardware' started by luker, 6 Feb 2011.
  1. luker
    luker What's a Dremel?
    3 Jan 2010
    hi im going to run two loops
    1st 2 x 360 rads+ cpu (2500k)
    2nd 2 x 360 rads + 560 sli
    can any one tell me what pumps would be best thanks
  2. mars-bar-man
    mars-bar-man Side bewb.
    17 Apr 2009
    Laing DDC or Laing D5.
  3. Nexxo
    23 Oct 2001
    Probably Laing DDCs, because they are relatively quiet. D5's are more powerful than you need, and two of them would get fairly noisy.
  4. luker
    3 Jan 2010
    many thanks should i leave them standard or with modded tops
  5. Krikkit
    21 Jan 2003
    Depends what kind of loop you want - restops are popular for simplifying the system and providing a good choice of barbs.
  6. GeorgeStorm
    16 Dec 2008
    DDCs are a good shout
    However, why on earth have you got your rads setup like that?
    Neither loop would need 2 360s.
    Better to save your money and upgrade the gpus or something
  7. Krikkit
    21 Jan 2003
    Good point, I didn't even look at the rad setup. Unless you're going with super silent mega low-flow fans then 4x360's is total overkill. :p
  8. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    What radiators are you using? I run both my Core2Quad and my 5870 off one XSPC RX360 and the temps are low, very low. And my whole system is quiet.
    You could run all of that off one rx360 with a D5 easily...
  9. luker
    3 Jan 2010
    thanks for advice will stick with just 2 rads
  10. Bloody_Pete
    11 Aug 2008
    Which rads are you using? As if they're the double thick ones like the XSPC RX series then you'll only need one :)
  11. dead beat
    dead beat Rippin six 4 life
    15 Feb 2009
    I run two overclocked GTX 580's off a single XSPC RX360 rad and my temps have never been higher than 56 degrees even under full load.
  12. Nexxo
    23 Oct 2001
    ^^^ The man speaketh the truth. I run two Opteron 250's (89W each) and an ATi Radeon 1650 (50W) on a single BIX. Temps stay nicely in the 45C range.
    People always overestimate the size of radiator needed.
  13. Bloody_Pete
    11 Aug 2008
    Someone needs an upgrade... :p
