Electronics What resistor should I use to lower fan speed?
Discussion in 'Modding' started by phinix, 28 Dec 2008.
  1. phinix
    phinix RIP Waynio...
    28 Apr 2006
    I have a 12v fan - 0.30A. What resistor should I solder in to lower the speed about half or sth..? I believe it goes in red cable.. right?
  2. ch424
    ch424 Design Warrior
    26 May 2004
    15Ohm, 1.5W
    V=IR, so the voltage across the fan will be 12-0.3x15=7.5V
    That should make it run pretty quietly but not stall!
    Power dissipated by the resistor will be P=I2R=0.32x15=1.35W
    Therefore you need a 1.5W resistor to stop it burning up.
    hth
    ch424
  3. phinix
    28 Apr 2006
    :( I have only 0.5W resistors... ok, so need to buy 1.5W one..
    thanks!
  4. cpemma
    cpemma Ecky thump
    27 Nov 2001
    But the current won't still be 0.3A at the reduced voltage.
    First calculate the fan resistance, 12/0.3 = 40 ohms
    So a 30 ohms resistor in series will take 30/(40+30) X 12 = 5V approx, leaving 7V for the fan, the current will be 12/(40+30) = 0.17A approx, so power wasted by the resistor = 5 x 0.17 = 0.88W
    You can use a couple of equal 0.5W resistors in series or parallel as a 1W, they share the heat.
    To save getting the calculator out, I posted a link here only yesterday.
  5. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    If you want to go even simpler then just splice the wires with a USB cable and then you have a 5 volt USB fan
  6. GoodBytes
    20 Jan 2007
    If this is a 4-pin molex connector (but only uses 2 wire) internal case fan, than just flip the plug on reverse and force it in. Like so: http://www.kenable.co.uk/images/case_fan_80mm_4pin_molex.jpg
    That's what I did. You get half speed right there. Just DO NOT plug anything on the other end of the power plug of the fan, as IT WILL DAMAGE it. So make sure at 100% that you use that ONLY for your plug. I won't be responsible for any damage.
