What resolution are you running?
Discussion in 'General' started by WilHarris, 14 Nov 2001.
What res do you view BiT in?
  1. 800x600 or below
    4 vote(s)
    10.0%
  2. 1024x768
    14 vote(s)
    35.0%
  3. 1280x960 / 1280x1024
    15 vote(s)
    37.5%
  4. 1600x1200 or above
    7 vote(s)
    17.5%
  1. WilHarris
    WilHarris Just another nobody Moderator
    16 Jun 2001
    Just wonderin...anyone having problems with the new bit layout?
  2. K
    K 528491
    31 Oct 2001
    1024x768 at work - Totally fine, in a small window most of the time too.
    1280x1024 at home - Totally fine full screen at all times.
    All looks good over here :D
  3. Cheese
    Cheese Doc
    6 Oct 2001
    1280x1024
    :D
    r.
  4. linear
    linear Minimodder
    5 Oct 2001
    The only thing that seems off to me is the custom color siggies that some of you have done, but not updated to work with the new bg colors.
    *cough*cheeseman*cough*
  5. Cheese
    Cheese Doc
    6 Oct 2001
    Oh ok I'll change it... it's so hard though, so few colours work on a pale blue background...
    r.
    EDIT: All gone now... I hope you're happy :(
  6. CRASHER
    CRASHER What's a Dremel?
    13 Nov 2001
    mines on 1024x768 and mines ok on full screen:D
  7. vivid
    vivid down in fraggle rock
    24 Sep 2001
    mines 1024x768 on a nice big 19" monitor :D
  8. SuperScrubber
    SuperScrubber Mad Chemist.....buwahahaa
    12 Mar 2001
    Why cant I vote in polls - everytime I try I get ;
    " vBulletin Message
    The action you have attempted could not be performed as your session appears to be invalid. Click the below link to attempt this action again with a new session.
    Try this action again!"
    ...............whats going on - dont like being thought of as invalid :(
    I use 1280x1024 btw ............ :)
  9. Cheese
    Cheese Doc
    6 Oct 2001
    I have the same prob super... it's probably a college thing :(
    r.
  10. Guest-16
    Guest-16 Guest
    :( 1024 is the biggest i can get off a 4yr old 15" 60hz moniter :(
  11. vivid
    24 Sep 2001
    i had that same voteing problem over the school network today, i just clicked on the try again link and it worked, still very wierd though :confused:
  12. :: Dugy ::
    :: Dugy :: Turkey
    29 Jun 2001
    with web designs its ALWAYS gonna work with HIGHER resolutions BUT, the real test is with lower ones, like with bit, it dosnt all fit with 800x600
  13. WilHarris
    16 Jun 2001
    YEah, minimum res for bit is 1024x768..i was just wondering how many of you don't run that and, by the looks of it, all seems good :)
  14. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    the start bar scares me.... must make it as small as possible
  15. Guest-16
    Guest-16 Guest
    frankly ppl who run in less then 1024x768 should be shot (unless its a medical condition and they cant read - then there is accessability options).
    nuff said - you dont get a decent enough desktop otherwise, and you get a mouse the size of my fist!
  16. RTT
    RTT #parp
    12 Mar 2001
    agreed :D
  17. PC4LIFE
    PC4LIFE What's a Dremel?
    11 Oct 2001
    1280x1024 on this comp. 1600x1200 on the workstation. The comp in my room I really care about.:D
  18. IsaacSibson
    IsaacSibson Banned
    15 Nov 2001
    1600x1200+1280x1024 here (dual head...MMmmmm).
    Oh, and the layout works fine maximised on the 1600x1200.
  19. Celt
    Celt What's a Dremel?
    14 Jun 2001
    i am on 1600x1200 on a 21"
    my father runs two 21" monitors each at 1600x1200 dual head
    3200x1200
    crezzy. he doesn't even need them.
  20. RTT
    RTT #parp
    12 Mar 2001
    <RTT>screen[1152x864 32bit @ 100Hz]
