What resolution are you running?
Discussion in 'General' started by WilHarris, 14 Nov 2001.
What res do you view BiT in?
  1. 800x600 or below
    4 vote(s)
    10.0%
  2. 1024x768
    14 vote(s)
    35.0%
  3. 1280x960 / 1280x1024
    15 vote(s)
    37.5%
  4. 1600x1200 or above
    7 vote(s)
    17.5%
  1. Gandi69
    Gandi69 Like to get busy wit fizzy..
    17 Jul 2001
    I can only pump 800x600 at 60hz outta this Ghey 15" from 1997
    :( Shud do 1024x768 but dont!?
  2. RTT
    RTT #parp
    12 Mar 2001
    i had a 14" that said it'd do 1024x768 but it only did 800x600.
  3. PC4LIFE
    PC4LIFE What's a Dremel?
    11 Oct 2001
    /me shudders at the thought of running 800x600 I Will Never Go Back to that res again.
  4. RTT
    RTT #parp
    12 Mar 2001
    lol, i remember win95 days running 640*480 :D
  5. Guest-16
    Guest-16 Guest
    soz just read your sig Sk8erFat and have to say this:
    ...BULLS ON PAR-ADE!! - dun-dun-dun-dun-dun-dun.. dun-dun-dun-dun-dun... *jump around a little*
    Ahem. :D
    My 15" 60hz jobby does 1024x768, and is only meant todo 800x600 :D:D i got it to run at 72hz but the screen started flickering and you just *know* its gonna go pop any minute, so its back to bog standard 60 now.
  6. RTT
    RTT #parp
    12 Mar 2001
    NOW TESTIFY!!! :D
  7. Tim S
    Tim S OG
    8 Nov 2001
    I run at 1024x768 @ 85Hz, I can run higher, but at 1280x1024 I get the 60Hz look, I've got flicker sensitive eyes, and I can see 75Hz drawing, so 60Hz kills my head!
    I think me next upgrade has to be a nice....errrrrr 17" sony, or maybe 19" (depends on funds of course :D) With being a student its more likely to be the 17", I'm already well into debt this year :rolleyes:
    Plus I wanna get a nice lil 10" monitor for sticking all the things like AIM, MSN, MBM5, winamp, etc... plus I could watch simpsons episodes at the same time as browsing :D
    Just means getting a PCI grafix card to run the lil monitor off.... If I get one Ill have to post some pix :D
    Cheers
    Biggie
  8. RTT
    RTT #parp
    12 Mar 2001
    i can see 75hz drawring too :(
    anything below 80 kills me :eek:
  9. Guest-16
    Guest-16 Guest
    Here is something you cant understand... how can i just... kill a man! ....Duh duh duh duh duh... /me has LOADS of ratm stuff now, just completin my Battle of LA album and i have everything :D
    ...turn on your radio - na fcuk it - turn it off, fear is your only god on the raido... *guitar*... :D:D
    Its 2:15am and im STILL listenin to it after downloadin about a gig of pron on kazaa... :D
  10. ChriX
    ChriX ^
    30 Aug 2001
    ditto to RTT
    edit: by that i mean 1152x864x32@100Hz
  11. howesey
    howesey What's a Dremel?
    17 Aug 2001
    1920x1080 here. Looks fine.
    Looks ok at 1024x768. I will never go back to that crappy res!
  12. PC4LIFE
    11 Oct 2001
    Ph33r my 60Hz on a 17in monitor and 65Hz on my 19in
  13. vivid
    vivid down in fraggle rock
    24 Sep 2001
    im now runnin 1152x864 at 85 hertz, i used 2 run 1024x768 at 60 hertz but it never bothered me atall, and i havent noticed any difference runnin it at higher hertz like i do know
  14. SFromley
    SFromley What's a Dremel?
    11 Nov 2001
    1024*768 @ 100hz here.
  15. PC4LIFE
    11 Oct 2001
    SFromley I know you ph33r my 60Hz
  16. SFromley
    11 Nov 2001
    60hz PC4LIFE: I don't care what system you're from, that's *gotta* hurt!
  17. PC4LIFE
    11 Oct 2001
    I must be strange then.
  18. RTT
    RTT #parp
    12 Mar 2001
    vivid on a 19" you should run at LEAST 1280x1024, and set the refresh rate way higher than 86Hz man!!!
  19. vivid
    24 Sep 2001
    i can but, when i try to resize the desktop to fit the screen it misses out around the edges, v wierd :confused:
  20. RTT
    RTT #parp
    12 Mar 2001
    use the OSD to resize it ;)
    i'd suggest nothing lower than 100Hz for 1152x864 ;)
