Other What resolution is your phone?
Discussion in 'General' started by Cerberus90, 4 Feb 2013.
  1. rollo
    rollo Modder
    16 May 2008
    depends who you want to make apps for.
    People on higher resolution phones are more likely to buy your application than somebody with a low resolution phone.
    Resolution is a decent indication of any as what the rest of the spec will look like.
    480x800 is now 2 years old ( samsung galaxy s2 had it as does the ACE)
    your making a game application you say? Unless its tower defence how many 2 year old phones are going to be able to run it at decent fps.
  2. docodine
    docodine killed a guy once
    10 Feb 2007
    768 x 1280
  3. Blazza181
    Blazza181 SVM PLACENTA CASEI
    19 Apr 2011
    480 x 800, Orange San Francisco.
  4. wiby645
    wiby645 Minimodder
    26 Jul 2007
    720x1280 Sony xperia S (lt26i)
  5. Shirty
    18 Apr 1982
    Xperia U
    854 x 480
    3.5 inches
    280ppi
  6. Bhuvsta
    Bhuvsta Minimodder
    1 Dec 2007
    800x1280
    Samsung Galaxy Note.
  7. Cerberus90
    Cerberus90 Car Spannerer
    23 Apr 2009
    It's not going to be full 3D FPS or anything.
    To start with, it's going to be simple 2D in openGL.
    Most phones right back to android 2.1 should be able to run it at a minimum of 30fps from what I've seen and done so far. It's a pretty efficient SDK.
    As I've said as well, it's not only going to run on 480x800, it will run on any resolution and scale accordingly. This is just to get an idea of what sort of scale my initial sprites/textures need/should be. Obviously if I'd based around 240x320, scaling up to anything bigger than 480x800 wouldn't look great.
    I can always rescale afterwards again if I need to. Just adjust a few numbers.
  8. biojellywobbles
    biojellywobbles Minimodder
    12 Feb 2011
    320×480 Galaxy Ace
    Still just about living with the wonders of gingerbread
  9. lcdguy
    lcdguy Minimodder
    25 May 2004
    Lg Nexus 4
    768x1280
    318ppi
  10. Boogle
    Boogle What's a Dremel?
    8 Mar 2002
    Original assets should target the highest DPI around, you can scale down but not up.
    Then it's a case of potentially different UIs for different screen sizes. Ideally you don't want to target a 'specific screen' as canonical.
    If you do want a 'one size fits all', then you make the UI work with the smallest screen size you're supporting, and provide assets for the different DPIs as neccesary.
    In short targetting a specific screen is a bad idea, regardless of platform.
  11. ggicollegeindia
    ggicollegeindia What's a Dremel?
    5 Jan 2012
    I've iphone 4s and resolution is 960×640
