Modding What should cost less ? (Wooden \ Perspex)
Discussion in 'Modding' started by Eran, 26 Jan 2005.
  1. Eran
    Eran What's a Dremel?
    6 Nov 2004
    Im making a low budget case for my HTPC,
    and I want to know what should cost me more, a case made out of Wood and Perspex, or a case made by 100% perspex ?
    thynx in advance :rock:
  2. Mattt
    Mattt Minimodder
    12 Nov 2001
    depends on the type of wood tbh and the amount of the wood you would use.
    but in genral wood is cheaper then perpex (at the low budget end)
  3. RobbieGSM
    RobbieGSM Banned
    26 Nov 2003
    As Matt has said, wood would be cheaper, depending on which type of would you'd be using. Perspex, well i'm not too sure on prices per spq meter, but i don't think it's too much more then wood anyway.
    Rob.
  4. purepope
    purepope Banned
    17 Jan 2005
    if u buy cheep wood its alot cheeper, and with the rite finish it can look good but perpex will cost u that penny more, (like choosing cheep brick to not as cheep brick)
