Apple What should I buy?
Discussion in 'Software' started by giganten, 15 Dec 2005.
  1. giganten
    giganten Artist
    20 Oct 2004
    Okay.. I dont know so much about mac :confused:...
    I will use it for web browsing, photo editing, and maybe some music. But dont know what to buy, what is the best thing to spend my money on?
    1: Mac mini 1.42ghz 80gb, and a ipod nano 2gb.
    2: Ibook 12"inch and a LeBAG [​IMG]
    this will be littel more expensive..
    Thanks for help...
  2. seebul
    seebul Minimodder
    9 Aug 2005
    well it depends what you want doesn't it? do you want a desktop or a laptop? personally id go with an ibook because there amazing :D and of course they have a better spec than the mac mini.
    EDIT: looks like the mac mini actually has about the same spec as a ibook, my bad.
  3. Lovah
    Lovah Apple and Canon fanboy
    10 Jul 2002
    Don't forget you need a screen with the macmini. They are very likely in specs, so if you don't have a screen to spare atm, I would definatly go with the iBook. It will portable and the price difference will be very small.. definatly worth the little extra to go portable.
    good luck
    L
  4. Sam0r
    Sam0r It's been a while
    24 Jun 2005
    The iBook has a slight advantage over the mini, but only in the graphics department, ie you can have two screens (mirror and spanning with a hack) and its also a Radeon 9500Mobility, which isn't a bad card.
  5. Tomm
    Tomm I also ride trials :¬)
    12 Apr 2004
    Hmm, how comes the 12" Powerbook only has a 5200 then? Although it does have more memory, surely a 9550 is more powerful than a 5200?
  6. Sam0r
    24 Jun 2005
    You'd be suprised! I thought powerbooks came with 9700's? Or maybe the 12" comes with a 5200, dunno.
    The 9550m is pretty dire though, It doesnt play halo very well at all.
  7. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    Get a cheaper Windows laptop.
  8. Sam0r
    24 Jun 2005
    :eyebrow:
  9. Lovah
    10 Jul 2002
    Wrong subforum! :grr:
  10. seebul
    seebul Minimodder
    9 Aug 2005
    yer!!!! get out :D
  11. giganten
    giganten Artist
    20 Oct 2004
    No. :wallbash: i dont want a windows laptop...
    I will not play much on it. But is the 9550 good to use for photo editing (photoshop).
    The powerbooks are littel to expensive for me.
  12. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    yes of course, graphics matter little when it comes to editing.
  13. Valo
    Valo Minimodder
    11 Aug 2004
    as far as i can make out fx5200 produces less heat and provides better battery life than mob radeon 9500, so i guess that's how it made its way into uber-portable 12" powerbook :) and its pc version plays gta-sa very nicely :)
  14. Sam0r
    24 Jun 2005
    OT:
    I'm actually quite suprised at what the 5200's are capable of. My friend used to play CS:Source on one, and managed to get good framerates!
  15. Valo
    Valo Minimodder
    11 Aug 2004
    i managed to run battlefield 2 on my fx5200 go:) and actually could play it - 800x600 lowest details, but still, ownage :)
  16. phantomxc
    phantomxc What's a Dremel?
    7 Dec 2004
    12 inch pb does come with the 5200 go, i was just ripping one apart like an hour ago(worst design by apple) 15 and 17 both have 128 9700s. (i love working on those) i think the ibook and mac mini only have 32 mb of vram though ibook being the 9550 and the mini being the 9200. the i book is limted on resolution though and for photoshop and stuff like that it would bother me. i think the max on the mini is 1280 as the ibook is 1024
  17. Tomm
    12 Apr 2004
    I can say unequivocally that the (current) 12" Powerbook has better graphics capabilities than the current 12" iBook :)
