What Size Fan?
Discussion in 'Hardware' started by AW3K, 27 Dec 2001.
  1. AW3K
    AW3K What's a Dremel?
    3 Nov 2001
    hi can any one help me with this?
    what size fan do you rekon i can fit on the back of my motherboard tray?
    cheers
    AW3K
  2. Bursar
    Bursar What's a Dremel?
    6 May 2001
    You should be able to get an 80mm fan or smaller.
    I can't see the point of sticking them on the back of the board though. All it really does is help cool the termal sensor rather than make any real difference to the core temps.
  3. AW3K
    3 Nov 2001
    i ment above the printer port as i want it to take air out of the case like a lian-li.
    soz if i was a bit confusing.
    AW3K
  4. Guest-16
    Guest-16 Guest
    looks like a 60mm one m8
  5. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    yeah either 60 or 40 - a bit of modding and you could fit a few 80mm fans on there
    looks a bit like my gigabyte ga-5ax mobo
  6. AW3K
    3 Nov 2001
    cheers m8
    and it is a gigabyte ga-5ax
    looking at the picture again it looks like a 40 . what decent 40's are available.
    later
    AW3K
  7. AW3K
    3 Nov 2001
    what would be the best way to put a 60mm fan onto this as it is like a 2 tear set up?
    cheers
    AW3K
  8. RTT
    RTT #parp
    12 Mar 2001
    if you do put a fan in, you might wanna cut that grille out behind it so that the fan can grab more air :)
