Modding What size rivets!
Discussion in 'Modding' started by Parge, 27 Nov 2012.
  1. Parge
    16 Jul 2010
    Just treated myself to a rivet gun! Oh the excitement!
    Now, I need to get some rivets, before I order, is there a standard size for case rivets or what?
  2. djzic
    djzic Bokehlicious!
    8 Nov 2010
    Get some from here. The quality is awesome, you won't regret it ;)
  3. Parge
    16 Jul 2010
    Ok will do! And my second question - what is the name of the type of lock used on on Army Ammo boxes? I want to use it on a case door.
    See below...
  4. jamsand
    jamsand Minimodder
    21 May 2011
    Is it a latch lock???
    nope
  5. Dmlindley
    Dmlindley What's a Dremel?
    24 Nov 2012
    I believe you might be looking for an old style bailed latch
  6. jay2
    jay2 Indonesian Modder
    3 Oct 2012
    There's some size of rivets around. To make sure just bought a pack of 1.5mm, 2mm, 2.5mm on your nearby market. They are less than a dollar for a pack.
    I use rivets but i forgot their size for case. And depends on your drill hole, you can use smaller of bigger rivet nail.
  7. Parge
    16 Jul 2010
    Thanks for that suggestion - googling doesn't bring much up though.
    Yeah, I'll just pick up a few different sizes to try out.
  8. David
    7 Apr 2009
    I used a 3.5mm bit to drill out my rivets - but I'm not sure if rivets are sized by the stem or collar.
  9. Cheapskate
    13 May 2007
    You might find the latches in hardware sites like Rockler.
  10. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    1/8" Pop-Rivet with Gripe range .092" - .125" is best for PC chassis :thumb:
