Other What software to monitor temperatures?
Discussion in 'Software' started by nescafe, 20 Aug 2010.
  1. nescafe
    nescafe Minimodder
    8 Sep 2009
    What programs are the best for monitoring the temperatures of your motherboard and graphics cards?Is there anything that will control fan speeds too??
    Cheers Chris
  2. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    I like everest.. fan control probably afterburner or rivatuner
    what I did was flash in my fan's ramp up speed from 57-64C.. then it doesn't matter what software your running
  3. Teelzebub
    27 Nov 2009
    I use all of these, Real temp / core temp / Gpuz and MSI Afterburner for GPU fan speeds
  4. ed_456
    ed_456 The Artful Bodger
    12 Oct 2009
    I myself use HWMonitor. Works fine for me, and its handy having all your temperatures and voltages in one place.
  5. Cadair
    Cadair What's a Dremel?
    14 Jun 2010
    I use speed Fan, it makes my pc reboot if i try and adjust fan speeds [i think this is because I have not selected the correct Motherboard] but the temperature bit works ok.
    http://www.almico.com/speedfan.php
  6. Ficky Pucker
    Ficky Pucker I
    9 Jul 2009
    hwmonitor
  7. lamboman
    lamboman What's a Dremel?
    25 Jul 2006
    Personally, I used RivaTuner when checking graphics card temperatures (don't now because X1950 Pro's basically don't overclock...) and always use CPU-Z for checking processor temperatures. Generally, CPU-Z tends to be consistently the most accurate out of the temperature monitoring programs, and certainly one of the most popular.
  8. Yslen
    Yslen Lord of the Twenty-Seventh Circle
    3 Mar 2010
    Rivatuner wins by a country mile as far as i'm concerned. I can see all the info I want (including temps) while gaming, plus it logs each session to a file, starting as soon as I boot. It's very useful being able to go back and look at the relationships between frame rate and CPU/GPU/RAM usage - quite revealing!
    Rivatuner can also control GPU fan speeds.
    For simple desktop monitoring in real time, I use HWmonitor, because it's a no-hassle way of doing things. Rivatuner requires a fair bit of setting up, and it's not as quick to see temperatures (etc) at a glance unless you're in fullscreen 3D.
