Cooling What TIM?
Discussion in 'Hardware' started by Arboreal, 11 May 2017.
  1. Arboreal
    21 Jan 2011
    I've finally finished the tube of old sliver grey Akasa TIM that I've had for a few years.
    Any recommendations for a sensible day to day TIM that works and isn't madly expensive?
    I usually use the squished blob method of application on CPUs these day...
  2. Guest-56605
    Guest-56605 Guest
    That's a no brainer, Thermal Grizzly Kryonaut High Performance (a bit of a gobful lol) but applies smoothly and evenly - it's performance is also first rate :thumb:
  3. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    This ^
    Been using it since it came out and it's cracking stuff.
  4. Yadda
    Yadda Minimodder
    25 Jul 2003
    I used MX4 last time. Seems to be doing a good job.
  5. David
    7 Apr 2009
    Still working my way through a 30g tube of MX-2. No complaints.
    CoolLaboratory Liquid Pro is rather excellent too.
  6. Pete J
    Pete J Employed scum
    28 Sep 2009
    I'm a fan of IC Diamond myself.
  7. The_Crapman
    The_Crapman Don't phone it's just for fun. Lover of bit-tech
    5 Dec 2011
    A thoroughly nice Tim.
  8. Vault-Tec
    30 Aug 2015
    But dim :D
  9. Yadda
    Yadda Minimodder
    25 Jul 2003
    "Juss gan five-tae-'leven."
  10. adidan
    25 Mar 2009
    Currently use Deepcool Z5.
    Standard clock 3770 in a matx case with a Hyper 103 cooler that just has a 92mm fan and it never goes over 59 degrees. Performs much better than AS stuff for me and inexpensive. Think you can only get their stuff from Amazon over here, not sure though.
  11. B1GBUD
    B1GBUD ¯\_(ツ)_/¯ Accidentally Funny
    29 May 2008
    I've always used Arctic Silver 5, no complaints here
  12. javaman
    javaman May irritate Eyes
    10 May 2009
    Always thought it never made a difference. *ducks for cover*
  13. TheMadDutchDude
    23 Aug 2013
    AS5 is so 2006. :D
    Kryonaut from Thermal Grizzly is probably my favourite one. Yes, it's expensive, but it is great. Easy to apply/remove and it performs more or less the best, with the exception of liquid metal options.
  14. B1GBUD
    29 May 2008
    Retro cheesecake :rock:
  15. Arboreal
    21 Jan 2011
    I'm overwhelmed! :lol:
    I've never has such a large response to a request on here, I'm humbled.
    So much choice; I was going to go for Arctic MX-2, but the Thermal Grizzly Kryonaut is now calling to me
  16. d_stilgar
    d_stilgar Old School Modder
    11 Feb 2010
    I use IC diamond in my builds.
    The big thing is that I do a build and usually don't touch it for 4+ years. Most performance thermal compounds will lose performance in that time, but IC diamond keeps up without need of reapplication. Most tests don't account for this either since it takes a long time to test long term performance.
    So choose your TIM based on its application. If you're going to highest possible performance, there are other TIMs out there, but if you're like me and aren't upgrading constantly, IC diamond is a very good choice.
  17. Arboreal
    21 Jan 2011
    Thanks for all the input, I found some MX2 at work, but will splash out on Grizzly next time I'm doing any important refits. :thumb:
