Long story short, I managed to drop a piece of metal onto my GPU because I'm really really smart like that . Anyway, the GPU seems to have chosen to short on the metal, as a metal oxide like substance has formed on the piece, that I have removed,; the HD 5850 now doesn't work. This is almost certainly a short circuit, I believe. I can insulate the part on the card that shorts with blue-tack like adhesive rubber stuff, sorry I don't know the proper name and prevent it from smouldering/sparking, but there is no video displayed on the screen. The GPU seems to be dead. So, anyone know what I should do with it now? Well beyond warranty, but does anyone take GPU's for scrap, for instance? Or could I try to remove the excess material that is shorting it? Unless that is inside the layers of the PCB, in which case... XD Gunna let it sit and rot for now I spose, using my trusty old 8800gts
Usually when things short and go pop, thats it. A trip to hardware heaven is the next step. It might be repairable, but the damage has already been done by the sounds of it.
Just created a Flickr account so I can bring up photos. http://www.flickr.com/photos/72698299@N02/?saved=1 Can this hyperlink and followed to see the pics of the dead chip? Will post the piece of metal that I dropped (genius) when I find it (room pretty cluttered at the moment )
I did something very similar with a 4870 back in the day. Metal, sparks, smoke, blackened PCB. Its now an 800 stream processor paper weight
