Modding what to do with a game cube?
Discussion in 'Modding' started by sotu1, 24 Jun 2008.
  1. sotu1
    sotu1 Ex-Modder
    24 Aug 2007
    hey all, i got an old gamecube hanging around and i was wondering what i can do with the old thing. any suggestions? i'd like to mod a whole pc into it, kinda like a mac mini in a cube box but i don't know how that would work. any other ideas?
  2. tominated
    tominated What's a Dremel?
    28 May 2008
    it's called a mini-itx or nano-itx depending on the size of the box. if those are both too big, there is pico-itx
  3. Oreon_237
    Oreon_237 CHEA BRO!
    11 Dec 2007
    you could make the gamecube even smaller, but i like the pc in a case idea!
  4. sotu1
    sotu1 Ex-Modder
    24 Aug 2007
    ok, it looks like the pc in a cube box is viable. however i'd like it to do more than just run windows xp on bare minimum....it's gonna be a lan pc. but specifically for older games, ie civ 4, CS1.6 (maybe source if i can push it that hard!) can you help me with getting components together? i've never really dabbled in SFF pc components and the like.
    i guess what i'd look for is:
    CPU: highest speed i can get, ideally 1.8ghz
    hdd: maybe 32gb from a flash stick or something, or notbook sized HDD
    GPU: something like a nvidia 6600 would be fine or an old radeon 9800!
    psu: i guess 200w will be enough.
    a network port
    and say 4 usb connections for bits and pieces.
    possible?
  5. Xtrafresh
    Xtrafresh It never hurts to help
    27 Dec 2007
    build a 360 into it :lol:
    the above list should be possible i guess... hard, but possible.
  6. sotu1
    sotu1 Ex-Modder
    24 Aug 2007
  7. Farmboy UK
    Farmboy UK Hungry for knowledge
    19 Apr 2008
    Yea get a slimline slot load drive. Won't take up much space and no one will argue that slot loads are cool ha
  8. jhanlon303
    7 Sep 2006
    Being of the small form factor persuasion, one of the places I hang out at is here:
    http://www.mini-itx.com/
    Spend some time on the site and look at some of the projects for ideas.
    John
  9. Kierax
    Kierax What's a Dremel?
    5 Mar 2008
    If you do it, I can say 100% hands down it will win prizes for pure brilliance.
  10. sotu1
    sotu1 Ex-Modder
    24 Aug 2007
    at the moment it looks like only a pico itx will fit, but they're very limited in terms of what they can do and very expensive. the micro atx boards are a fraction too big (i havent measured the GC, but i think they're a bit smaller than 17x17 cm according to the net). i'm actually quite surprised no one has done it yet.
    anyone else got any suggestions on hardware?
  11. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    I was looking into this a while ago. It will have to be Pico-Itx. The Gamecube base has a fan built into it, so that's nice. You might want to wait for an atom or Isiah pico-itx motherboard to come out though.
    You could mod your router into it, or make it a NAS with a pico-itx board.
  12. GavX
    GavX What's a Dremel?
    5 Apr 2008
    hate to be Cpt Ruin-yer-mod but no way will the above fit in that, as awesome as it would be. Unless you invert something that means you can bend motherboards over to save space, as even a mATX is way too big for a gamecube. Prove me wrong if you can though, as it would be awesome!
  13. Langer
    Langer Jesse Lang
    24 Jan 2004
    @gavX
    This is more than possible... with the below. (click for link)
    I have one of these Pico-ITX boards and a, to-be attached, video card module (to aid in video playback). I have it attached to a 7" touch panel LCD and it runs Windows HomeServer. Eventually it will be installed internally inside my main rig Prometheus. These boards run great, suck almost no power, run very cool, and look even cooler. HIGHLY RECCOMENDED
  14. sotu1
    sotu1 Ex-Modder
    24 Aug 2007
    looking at this, it's entirely possible to whack a Pico ITX into this, but I really doubt it will do what i want.
    Langer, do you happen to have a copy of Civ 4 you could try on your Pico? All the rig has to do is play civ 4 multiplayer at a respectable rate and i'll consider it a success and go ahead with it.
    it really is a shame the mATX won't fit, that would have been perrrfect.
    btw, what's a NAS?
  15. Malketh
    Malketh What's a Dremel?
    22 Jan 2008
    It would be even more interesting/cooler if you could take a slim-line optical drive and somehow mod it to use the gamecube's top lid loading setup.
  16. sotu1
    sotu1 Ex-Modder
    24 Aug 2007
    yep, that would be uber good. i thought about it, but i think that's beyond me tbh!
  17. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    Clearly, what you should do, is put the GC into a PC :B
    I mean, the power is easy, it already runs within standard molex spec (I actually have a modified power cable for that exact purpose), the lid security can be bypassed easily, and the other switches are easily extended.
    Though, with the PC idea - adding a top loading CD drive shouldn't be too hard. I mean. The mechanism is all in place for you, and that lid can definitely lift the weight. Might need to check out those GC shells that've been molded to take full size DVD's, though, to get the right fit. It'd take a lot of planning and careful measurement, but totally worth it :B
  18. sotu1
    sotu1 Ex-Modder
    24 Aug 2007
    hmmm...looks like i'm going to say goodbye to my cube this weekend and gut that paperweight.
    liratheal, could you provide a few more details about what you've done to your cube and what's inside it?
  19. liratheal
    20 Nov 2005
    There's nothing in the shell :p I used to have my Xbox and GC in a Lian Li case a while back - Got pretty familiar with the GC internals. Most of my GC modding was centered around the actual console rather than the shell.
    There is a surprising amount of space inside the shell, but the lid (As I'm sure you've noticed) isn't quite big enough for a standard DVD/CD. There are a few companies that sell the raw shell with a modded top so it can take full size DVD's etc. Making it a lid based DVD drive would be quite fraught with trial and error, but would SO be worth it.
    I'd be tempted to do it with a standard tray based laptop drive, that way you don't have to worry so much about holding the disk down, thanks to the mechanism already used in laptop tray based drives - As I'm sure you're aware. Saves you having to be so precise with the lid spaces :D
  20. sotu1
    sotu1 Ex-Modder
    24 Aug 2007
    hmmm....damn that's well above my league, like, all i've ever done is paint my case and put a hole in it! now you're asking for me to rip open a laptop optical drive!? where can you get the cube shells from?
