Other What to do with an OLD computer?
Discussion in 'Hardware' started by Otis1337, 16 May 2009.
  1. Otis1337
    Otis1337 aka - Ripp3r
    28 Nov 2007
    A relative gave me his computer after upgrading to a newer PC...
    and its old... VERY old, where talking 128MB RAM, P3 CPU and 10GB HDD...
    Is it anygood for anything at all? or only good for the bin?
    BTW it came with a 15" LCD monitor which is a little damaged on the screen, but nothing to bad.
    Any idea's would be helpful:thumb:
  2. Paradigm Shifter
    10 May 2006
    Classic gaming rig? Hardware firewall?
  3. Diosjenin
    Diosjenin Thinker, Tweaker, Et Cetera
    14 Jul 2008
    I'd say either classic gaming rig or file server.
    - Diosjenin -
  4. Matticus
    Matticus ...
    23 Feb 2008
    Its good for giving to me :p
    Or a file server, which is what I would use it for.
    Or maybe some sort of freeview PC? So you can run your TV through it and record progs etc.
  5. capnPedro
    11 Apr 2007
    Some sort of server. File/print/torrent/firewall?
  6. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    File server or download/torrent box.
    Bear in mind though that a K6@450MHz running a heavily lited Server 2003 and µTorrent with two torrents uploading keeps the CPU usage all the time >50%!
  7. Jozo
    Jozo This is bit-tech
    14 Mar 2009
    Server (file/torrent/print) will do very fine if you use linux and disable the graphical interface.
    Dunno about recording TV programs cause if you wan't to record (or playback) high res it may have trouble.
  8. SazBard
    SazBard 10 PRINT "C64 FTW"
    28 Apr 2009
    freebsd and set it up to be a firewall...
  9. Otis1337
    28 Nov 2007
  10. Jux_Zeil
    Jux_Zeil What's a Dremel?
    30 Apr 2009
    MOD IT!
  11. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    throw linux+mpd on it and use it as an music streamer.
    it won't have nearly enough power for freeview, even if it's only SD.
  12. SazBard
    28 Apr 2009
    But running a GUI will take extra resources. Where as FreeBSD is just CLI, it will run better.
  13. RickDawson
    RickDawson Minimodder
    29 Mar 2006
    I know this first hand.
    started with a P3 866mhz (old computer)
    no good for freeview.
  14. steveo_mcg
    steveo_mcg What's a Dremel?
    26 May 2005
    mpd for streaming music, geexbox for sd playback, ipcop for a firewall or a headless server for what ever you want, internal web server or torrent box.
  15. flame696
    flame696 Terminating People Since 1980....
    15 May 2009
    what about a large paper weight?? or maybe a door stop?? if you really need to use it then as everyone says file server but i suggest give it to a charity shop so they can make some good use out of it! Be generous this year lol
  16. mm vr
    18 Nov 2007
    Put it into a corner or closet to gather dust until you need it.
  17. flame696
    15 May 2009
    lol yeh u could do that to but when is he ever going to need a pentium 3 pile of S**T!! hahahaha
  18. Krikkit
    21 Jan 2003
    Take it to the tip?
  19. flame696
    15 May 2009
    Give it away!!!! as i said BE GENEROUS!!!
  20. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    I recently binned my old P3-500 machine that I got free from a relative. I did however take out a few bits and donated them on the Bit-Tech forums first...
