Networks What to do with spare wireless routers?
Discussion in 'Hardware' started by sotu1, 9 Dec 2009.
  1. sotu1
    sotu1 Ex-Modder
    24 Aug 2007
    Hey guys,
    I recently moved house and lost my wireless router in the process so I went and bought a new one. I think managed to find my old router! so, just wondering if there's anything cool I can do with 2 routers?
    cheers for the tips as always ;D
  2. Sir Digby
    Sir Digby The Supprising Adventures
    18 Jan 2009
    If it's possible, play around with Tomato on the spare one without having to worry about loosing internet access when you break something?
  3. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    not really, as wireless is pretty lame. i went from wireless to cable and will never look back!
  4. DaTLiTe
    DaTLiTe What's a Dremel?
    26 Apr 2009
    ebay? or donations my way are welcome!:)
  5. fingerbob69
    fingerbob69 Minimodder
    5 Jul 2009
    Crack it open and try to work out why it so s***!?
  6. woodshop
    woodshop UnSeenly
    14 Oct 2003
    If you got a wifi dead spot in the house you can run a wire close to it. Then use the router as a WAP. Most work like that if you use one of the lan hub ports instead of the wap port.
  7. steleet
    steleet Did he death?
    22 Oct 2009
    Dicect it. Then see if you can put it back together.
    Even if you fail, you'll feel 10 years younger.
  8. lxrysprtmscl
    lxrysprtmscl Minimodder
    8 Sep 2008
    make it home to the internals of a macbook.
    information about the casemod here.
    lxrysprtmscl
  9. goldstar0011
    goldstar0011 Multimodder
    2 Sep 2007
    On same note then I have 2 Netgear routers that used to be for SKy but now unlocked, wondering what I can do with them
  10. motas
    motas What's a Dremel?
    7 Dec 2009
    Give it to me!!!:D
  11. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    I just happen to be looking for a wireless router.
  12. MaverickWill
    MaverickWill Dirty CPC Mackem
    26 Apr 2009
    And now we know what Hungary-UK postage rates are... ;)
    PS arrived this morning, was dropped off with neighbour because I'm in uni. Picking it up tonight, will let you know how excited I get!
    :D
  13. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    :D
    Hopefully everything is in one piece.
  14. Nodule
    Nodule What's a Dremel?
    1 Aug 2009
    You must be unfortunate or have bad kit as I've never had any problems with wireless in my house. Saves me getting in trouble for leading cables half way round the house too of course.
  15. Picarro
    Picarro What's a Dremel?
    9 Jun 2009
    wireless is okay 99% of the time, but when the lag starts, at the second you were about to pop some dewd in CSS, you get angry. Good thing my room is next to the server room. Makes pulling cables a lot easier :)
