Watercooling What to do?
Discussion in 'Hardware' started by joco2_uk, 7 Oct 2013.
  1. joco2_uk
    joco2_uk What's a Dremel?
    1 Sep 2009
    Teelzebub likes this.
  2. AlienwareAndy
    AlienwareAndy What's a Dremel?
    7 Dec 2009
    A 7970 Direct CU II graphics card, water cooling loop and a PC.
  3. joco2_uk
    1 Sep 2009
    That's a good start.
    I have the PC, but just wondering if this is worthwhile.
    Can you recommend the parts at all?
    Cheers!
  4. Teelzebub
    27 Nov 2009
    If you're starting from scratch the parts needed for a water cooling set up will cost more than the card you've linked, tbh unless you're planning to water cool the CPU as well I can't see it being worth it
  5. joco2_uk
    1 Sep 2009
    I would be up for the water cooling the whole thing. I just wanted to know a rough ball park figure really.
  6. Lance
    Lance Ender of discussions.
    6 May 2010
    Ball park: 200
    Thats based on a CPU & GPU cooler.
  7. TheStockBroker
    TheStockBroker Modder
    19 Nov 2009
    I'm with Lance, between 200 and 250 if not going all out.
  8. Tangster
    23 May 2009
    That £200 would be based on 2nd hand pricing too. Brand new, you're looking at £250-300.
    CPU Block: £40
    GPU Block(the one you listed): £78.82
    360 Rad: £40
    Pump: £55-70
    Res: £15-50
    Fittings: £20+
    Not including fans, tubing, coolant.
  9. damien c
    damien c Mad FPS Gamer
    31 Aug 2010
    It would be hard to really give a ball park figure.
    Let us know what case you have and what cpu you have.
    That will determine what rad(s) you need and what res/pump combo you can get away with.
  10. bdigital
    bdigital Is re-building his PC again
    10 Aug 2010
    Id say £300 - £350 to build a custom loop for gpu and cpu (including the little bits like fittings, water, tubing etc).
    Sent from my GT-I9505 using Tapatalk 4
  11. Lance
    6 May 2010
    No it would be very hard to give an exact or accurate figure. A ballpark figure doesn't need to be within any margin, so you simply do an extremely quick figure in your head and somehow the rest of us managed it.. Jesus why is this the answer for that everyone gives when you ask for technical help. He's not going to come after your knee caps if you're wrong.
    (boy do I need a chill pill - one of those days.)
  12. Teelzebub
    27 Nov 2009
    There you go
  13. Parge
    16 Jul 2010
    To be honest, I bought almost all my watercooling parts second hand. In fact the only things that are new is my tubes and fittings (and when I first started out they were second hand too).
    Think it cost me about £120.
  14. joco2_uk
    1 Sep 2009
    Well I have a Coolermaster CM690 II White Case.
    A 965 with a Antec KUHLER H2O 620 on it. It keeps the temps nice and low. Normally below 35c with a 3.9 clock.
    I was just wondering about water cooling the graphics card as a project really. Never done one and thought perhaps try it.
