PSU What to go for?!
Discussion in 'Hardware' started by jamieedodger, 9 Jun 2010.
  1. jamieedodger
    jamieedodger What's a Dremel?
    9 Jun 2010
    I've decided - more or less on a system and just ordered the case, but I'm in need of some help with a PSU as im getting fairly stuck - in terms of what size I need? Any help would be much appreciated again, excuse my noob-ness.
    So I've chosen:
    Intel i7 930 Processor
    Gigabyte GA-X58A-UD3R Motherboard
    6Gb (3x2Gb) Corsair Dominator, DDR3 PC3-12800 RAM
    1TB Samsung HDD
    DVDRW
    ATI 5850 1Gb Grapics Card
    But like I said I've got no idea what PSU to go for, I've trwaled through hours of reading on bit-tech.net forums but am still unsure... I've also used of the configurator websites which have said 700/800W do you think this is right?
    Thanks in advance!
  2. tristanperry
    tristanperry Minimodder
    22 May 2010
    I think a good 650W PSU will work okay with that. A similar system but with a Core i5 proc and with 4GB of Corsair XMS3 RAM will work fine on a quality 550W PSU, so I guess that 650W should be fine for the system you quoted.
    I'm not sure of what PSU is best at 650W, however CPC recommend the Antec TruePower New TP-650 (£80) which looks a pretty great PSU and should handle your system fine, IMO.
  3. Marine-RX179
    Marine-RX179 What's a Dremel?
    24 May 2010
    The Antec TruePower 650W would be good for that system even with an extra 5850 in it.
  4. mrhrk01
    mrhrk01 What's a Dremel?
    20 May 2010
  5. Marine-RX179
    24 May 2010
    Just managed to find these info from old post:
  6. Jipa
    5 Feb 2004
    Most sites already use i7-based, often overclocked, test beds for their GPU-reviews and system wattages, so what you see there is pretty much what you should expect. Roughly it's 150 W for the card, 100-150 W for the CPU and on top of that some 50-100 W for the rest of the system.
    Anything above 400 W would be adequate, but just to be safe and to hit the sweet spot of PSU-prices, something in the 500-700 W region is what you want.
    Personal faves are Corsair's TX and HX-series. £93 would buy you a lovely HX650.
  7. jamieedodger
    9 Jun 2010
    Excelent, thanks for the help!!
  8. roosauce
    roosauce Looking for xmas projects??
    12 Feb 2010
    I'll second the Antec truepower 650w. You could get away with less - as others have pointed out - but 650w will give you room to move to crossfire etc. later. The Antec is efficient, modular, and relatively cheap.
  9. EvilMerc
    EvilMerc Minimodder
    1 Feb 2010
    I'd go for a Corsair HX650W. The amount of cables you get with the TX is just mental, and you can't remove any of them, the HX is modular so this can easily be remedied.
    Corsairs are also pretty much the most reliable PSUs you can get and they run nice and cool and quiet.
  10. slaw
    slaw At Argos buying "gold"
    13 Feb 2003
    Hey
    Just something to think of. I have noticed that people are reporting a whining noise with certain power supplies and this MB. I have got a Hiper 880w which seems to be fine but i would do a search on the web before you decide which one to go for.
  11. Instagib
    Instagib Minimodder
    12 Mar 2010
    +1 for corsair 750HX.
