Modding What tool would be best?
Discussion in 'Modding' started by Buclao, 11 Jan 2008.
  1. Buclao
    Buclao What's a Dremel?
    25 Sep 2007
    I'm trying to cut a 16 gauge steel using a stencil and jig saw. I was wondering besides the Dremel, if there's any other tool(s) that would make it easier to cut out a stencil on steel?
  2. Guest-23315
    Guest-23315 Guest
    Is it a large item? Otherwise try and hand-fret saw. It'll take a while, but should look good.
  3. Buclao
    25 Sep 2007
    Well it's a tribal dragon. The measurement s about 8 x 10 possibly. Um, I was wondering more of a machine, like a scrool saw? router?
  4. slugbug
    slugbug Going Broke Saving Money
    12 Nov 2007
    A good jigsaw with a fine metal cutting blade.
  5. Rocket733
    Rocket733 Austerity - It's the only way
    27 Dec 2003
    Scroll saw might be easier, router won't be.
  6. talladega
    talladega I'm Squidward
    18 Aug 2007
    CNC Laser cutter. ;)
    good blades on scroll saw or jigsaw should work.
