what type of chipset mobo work with at gfx cards?
Discussion in 'Hardware' started by Dawny, 11 Dec 2005.
  1. Dawny
    Dawny What's a Dremel?
    1 Dec 2005
    well planning to get a ati x800gto, but no idea which type of chipset i need with it help!!
  2. Guest-16
    Guest-16 Guest
    Anything with PCI Express.
  3. hitman012
    hitman012 Minimodder
    6 May 2005
    Doesn't matter... any will work, provided it has support for your graphics card's interface. If you're buying the PCI-E version, I'd go for an nForce4 motherboard - they have a very rich feature set and are the most popular choice. It would be my personal recommendation.
    If you're planning on purchasing the AGP - stop! Don't bother with it if you're getting a whole new motherboard ;)
  4. Dawny
    1 Dec 2005
    so if my graphic controller is a nvida gforce, will that work with the ati gfx card?
  5. hitman012
    6 May 2005
    An nVidia graphics card will work with an ATI chipset and vice versa. They are connected using industry-defined standards, so there will be no compatibility issues.
  6. AWACS
    AWACS What's a Dremel?
    10 Jun 2005
    I take it you're going with pci-e. and you wondt prolly be using dual cards (crossfire or sli)... then just select a mobo that supports the slot typ that card needs... I run a ati x850 xt pe on a nf4 mobo (Asus a8n-sli deluxe), so I'd say it wont matter unless you're going to run dual card setups...
  7. Boswell
    Boswell Minimodder
    23 May 2005
    what sort of budget have you got.. we will advise what motherboard is best
  8. Dawny
    1 Dec 2005
    orite, thnx tat solves the problem, :D . and can some1 tell me wot firewire do? well buget, around 60 but i dont need a sli, want sata2 and for an amd processor.
  9. Boswell
    Boswell Minimodder
    23 May 2005
    *does-->
    "A high-speed serial-bus standard that offers enhanced connectivity and data transfer for video, audio and storage peripheral applications through a universal input/output (I/O) interface."
    - like usb though can be faster but used less often... apple made it and now they are getting rid of it :/
  10. AWACS
    10 Jun 2005
    it's a port that does about the same as USB... though firewire is more used among video editing
  11. hitman012
    6 May 2005
    I would recommend an Asus A8N-E or perhaps a Gigabyte K8V... I know it's not nF4, but they're good boards for budget machines.
  12. Dawny
    1 Dec 2005
  13. hitman012
    6 May 2005
    Why are you so set on SATA-II support? I assume you mean SATA 3Gb/s.... you do realise that current hard drives have not even maxed out half the bandwidth of the original SATA specification?
  14. Dawny
    1 Dec 2005
    dunno just on that site western digital sata2 is cheaper than sata. thought might as well get a sata2
  15. hitman012
    6 May 2005
    SATA is fully backwards compatible, so it doesn't matter what you buy.
  16. Guest-16
    Guest-16 Guest
