Build Advice What upgrades can I make to my computer for £80?
Discussion in 'Hardware' started by David164v8, 8 Feb 2013.
  1. David164v8
    David164v8 Minimodder
    29 Aug 2011
    Before I buy this mechanical keyboard, I was just wondering if there is anything that would be more worthwhile at around ~£80 or so. Here are my specs at the moment.
    3570K
    Z77-D3H
    AMD 6870
    Gelid Tranquillo
    Corsair Neutron 240GB
    Phantom 410
    Corsair HX650
    4GB DDR3 1600
    Asus Xonar DG
    Sennheiser 598
    Zalman Z-1 mic
    Logitech G400
    Sidewinder X4
    I mainly use the PC for gaming, and play at a resolution of 1360x768 (A waste, but I can't change my monitor right now...) This is a strange question I know, just finding it hard to justify £80 on just a keyboard.
  2. atc95
    atc95 I have the upgrade bug!
    3 Dec 2012
    Stick another 4gb stick of ram in there and possibly add another case fan (if required). Otherwise keyboard is your best bet. Alternatively you could sell current hardware and do a bigger upgrade e.g. 6870 to 7950 but that isn't that cost effective.
  3. sotu1
    sotu1 Ex-Modder
    24 Aug 2007
    seems like maybe save another 40 quid and get a budget monitor!
    otherwise the ram defo.
  4. Harlequin
    Harlequin Modder
    4 Jun 2004
    monitor defiantely!
  5. eagle123
    eagle123 What's a Dremel?
    19 Aug 2012
    get a monitor like a cheap ips monitor with 1080 hd resolutions let the colour come to you
    i got a asus pa238 top monitor, well worth that way
  6. GeorgeStorm
    16 Dec 2008
    You say you can't get a new monitor, I'm presuming that's not purely due to money.
    As a result, a keyboard would be a great purchase, you won't regret it :) (doesn't have to cost you that much either)
    Only other suggestion would be another 4gb of RAM.
  7. jamsand
    jamsand Minimodder
    21 May 2011
    Cheap mech Steelseries 6gv2 can be had for £50
  8. loftie
    loftie Modder
    14 Feb 2009
    If you haven't used one, and like your X4, I'd stick with the X4. I know everyone who has one bangs on about how good they are, but like someone said on a different thread, if you don't know any better you're not going to miss it. Ignorance is bliss - or in this case cheaper lol. Main reason why I've not gone near one.
