Electronics What would i need to.....
Discussion in 'Modding' started by [KT] Mike, 11 Jan 2004.
  1. [KT] Mike
    [KT] Mike What's a Dremel?
    5 Oct 2003
    Hi guys, I'm currently in the process of building my robot with a friend and we want to get some of the ugly things planned out before i go too far and forget. We have our motor speed controllers which are from the 4QD NCC-70 series. We've used these before, however when the time comes to wire up the bot the connectors are placed in such a way that this is incredibly hard. We have also decided that the boards may be overheating so we want to attach a larger heatsink to the mounting point and then install 2 fans in an enclosure to bring cool air in and remove it. I had an idea that we could place the boards in an enclosure and then wire the boards up to a front panel so it would be a case of just making simple connections in the final wire up. Now, I would liek some info as to the type of connectors to use. The connection points on the board themselves are 8mm spade connectors but what sort of connector on the front panel would you reccomend that could simply screw together? PS, they must be able to take 125 A + so nothing small ;-). Also, where can i find a bog standard HS that could attatch onto here:
    [​IMG] (red circles)
