Cooling What would you buy??
Discussion in 'Hardware' started by Drobbins, 17 May 2006.
  1. Drobbins
    Drobbins What's a Dremel?
    17 May 2006
    Hey guys,
    iam looking for some feedback here really,
    I was wondering if you could take 10 miniutes to read the following and give me your list, what iam looking for is a list of compoinents you would buy to make up the following loops.
    Small 3/8" Setup designed to cool a basic home system something like a low end htpc or office setup with maybe one CPU cooler, radiator, pump. reservoiur, and hose.
    Medium 3/8" setup designed to cool a minimalistic gaming rig with a CPU block, GPU block, radiator, pump, reserviour hose maybe some small additions.
    Large 3/8" setup a setup designed to cool almost every component on the computer and is designed to cool a high end gaming rig.
    Small 1/2" Setup designed to cool a basic home system something like a low end htpc or office setup with maybe one CPU cooler, radiator, pump. reservoiur, and hose.
    Medium 1/2" setup designed to cool a minimalistic gaming rig with a CPU block, GPU block, radiator, pump, reserviour hose maybe some small additions.
    Large 1/2" setup a setup designed to cool almost every component on the computer and is designed to cool a high end gaming rig.
    All i would like is a list of components you would use in the following setups and also some of the items you would expect to see at a Watercooling shop.
    Many Thanks for your time
    Drobbins
  2. Nexxo
    23 Oct 2001
    Here's a thought-why don't you start by telling us what you would buy, and we will give our opinion on it. :)
  3. Drobbins
    17 May 2006
    Iam doing some market research you see...i dont want to give to much away but i need for you guys to tell me what you would buy :hip:
    Drobbins
  4. Da_Rude_Baboon
    Da_Rude_Baboon What the?
    28 Mar 2002
    You should check out his webshop. The entire Aqua-Computer catalogue of products and they all cost £5! :rock:
    http://www.thewaterpeople.co.uk/
    As the customer i would prefer it if the person selling the products had done HIS research and could recommend products based on what would suit my needs and not resort to asking in a forum.
  5. Anobis
    Anobis What's a Dremel?
    28 Mar 2006
    And thay realy deliver? :eeek:
  6. Drobbins
    17 May 2006
    The site is not complete yet so please dont try and make any orders.
    Drobbins
  7. stev
    stev What's a Dremel?
    11 Aug 2005
    Why water cool? Would a good heat-pipe solution work better?
  8. asteroth
    asteroth What's a Dremel?
    8 Apr 2003
    i would go for a 7/16ths system. flexability of a 3/8s and comparable flow to a 1/2 inch
