Build Advice What would YOU do...?
Discussion in 'Hardware' started by Jeff Hine, 13 Jun 2019.
  1. Jeff Hine
    Jeff Hine Nothing special
    8 May 2009
    ... with £400 to balance the CPU/GPU load for the build I currently have?
    Most "taxing" (LOL, yeah right) thing I do with my machine is play WoW looking the best it can...
  2. Zoon
    Zoon Hunting Wabbits since the 80s
    12 Mar 2001
    If you can't maintain 60 FPS in line with your screen's 60Hz at the resolution you're playing with, then it's graphics you need not CPU in my opinion.
    You could look out for a 4790K just to squeeze every last drop outta your current platform, but honestly, selling that Vega for a 1080 and pocketing the leftovers from shopping your CPU too is probably gonna be best.
  3. Wakka
    Wakka Yo, eat this, ya?
    23 Feb 2017
    If all you're doing is WoW - £400 of pizza and beer, most probably.
    Yaka likes this.
  4. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    ^ This and wait to see what happens with next month's AMD release.
  5. Jeff Hine
    8 May 2009
    The CPU is working harder to keep up with the GPU; and @Wakka just confirms what I feel is the general consensus of the gaming world, that WoW is too s*** to need any (serious) hardware consideration.
    Why can't I want to play an old game looking at its best? What it needs to get it onto a PC is nothing like what it needs to run looking at it's best... but then if it doesn't need an i9 or an RTX to run, 'who cares'...?
  6. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    I have noticed with my 3570k it is definitely being bottle-necked in modern titles. Even things like HOI4 and Stellaris are a stretch if I'm watching stuff at the same time, so don't assume you won't actually gain frame rates if you watch content while playing WOW :)
    Jeff Hine likes this.
  7. Zoon
    12 Mar 2001
    So going back to my question, are you getting your 60 FPS at high detail?
    You mention above that your CPU is struggling - so your cheapest option is going to be getting a second hand 4790K. That will take you from 3.5ghz 4c/4t to 4.0ghz 4c/8t. It'll mean you can keep your RAM etc.
    On your motherboard you would probably get to 4.2 for a modest overclock without much worry either. Your old CPU will get you back about 75% of the purchase price of a second hand 4790k. Might balance out pretty well.
    £400 is going to get you a lower end motherboard, 16GB RAM and maybe £200-£250 to spend on a Ryzen 3. Said Ryzen 3 will have more cores, sure, but actually, the 4790K is going to get you more mhz, which will probably make more difference to you with WoW which is a bit older and less likely to take advantage of more cores as well as a more modern game.
  8. adidan
    25 Mar 2009
    The 3600and 3600x are expected to be in that price bracket, i'll take that bet on which will be better. :p:
  9. Jeff Hine
    8 May 2009
    I run level 7 at 60-70fps, but not without the occasion 'non-crash freeze'.
    I don't trust second-hand... and am paranoid about
    I'm looking at using some variant of this as a foundation for an upgrade, as my GPU & monitor are a few months old.
    EDIT:
    The idea of selling MY kit second-hand fills me with more dread than buying second hand.
  10. Zoon
    12 Mar 2001
    I have to admit I didn’t realise the clocks were quite so high on Ryzen 3. The 3600 should easily be in budget and will deliver six cores/12t at 3.6ghz or the 3600X will deliver six cores/12t at 3.8ghz for a bit more but maybe still in budget.
    I think I’m reconsidering my position on the above now.
  11. Zoon
    12 Mar 2001
    I’ve been a member since day one, my user ID is literally number 11.
    I’ve been selling and buying on and off probably for the past ten years or so on this forum.
    There have been very, very few instances of issues; certainly only one ban from selling this year I can recall and that’s because the guy was a trader selling multiple lots, against forum rules. I’ve bought stuff for builds I did for friends and family here even and never had a single issue. I’d say you’re pretty safe. But it’s up to your personal comfort levels of course.
    adidan likes this.
  12. adidan
    25 Mar 2009
    I'd echo this 100%
  13. Anfield
    Anfield Well-Known Member
    15 Jan 2010
    Although to stay in budget may be best off looking at the various X470 boards that will no doubt pop up in the marketplace further down.
    (X570 mobos will be rather pricey and the budget chipset ain't due until the end of the year)
    adidan likes this.
  14. Sa mod pc design
    Sa mod pc design New Member
    7 May 2019
    Go with x470 and amd ryzen
  15. Jeff Hine
    8 May 2009
    I hate - as does WoW; it hangs with the feeling it's going to crash, but it recovers - the imbalance of old & new on this rig.
    Should I be - more realistically - looking at what a 4690K cost/sold for as a replacement price-point, rather than trying to be a tight-a*** (see my other similarly themed threads) to get a DDR4 replacement/equivalent version to get the best out of my RX Vega 56?
    EDIT:
    I dunno what the board I have cost; it was a 50th birthday present.
  16. Zoon
    12 Mar 2001
    4690K - probably £50-£70.
    The Z97X Gaming 3 ... on Ebay you might expect to get £80 - £100 as the 4th gen boards are in pretty low supply. However that's definitely inflated for ebay. On selling forums you'd probably looking £60-£70.
  17. Jeff Hine
    8 May 2009
    Put it another way... when I bought my 4690K, I paid £195 for it - is that the price-point I should be looking at for a replacement...?
    Something tells me that a R5 2600 - at ~£130, for examples' sake - isn't gonna be that great an improvement, but a R7 2700 would be on a similar performance level.
    I get that efficiency, etc get better with advances in tech. - requiring slower speeds to get the same performance - but if the 2600 isn't aimed at the same market as the 4690K was, then I need to be looking more closely at the 2700 sector/pricing... don't I?
  18. Zoon
    12 Mar 2001
    So as I said above, some games, like WoW I believe, are optimised for multicore, but only upto quad cores. Over that it doesn't matter. Or didn't used to, anyway. That's why I suggested a secondhand 4790k to you, because it's 4.0GHZ x quad core. There's no real difference in computing between a 4790K and a 7700K.
    So, moving on with a comparison to Ryzen. A couple comparisons to look at.
    4690k vs Ryzen 5 2600 - there's probably no clear winner between these two.
    https://cpu.userbenchmark.com/Compare/Intel-Core-i5-4690K-vs-AMD-Ryzen-5-2600/2432vs3955
    A Ryzen 5 2600 has a slower clock speed than your 4690K, by a whole 100MHZ. Will you feel that? I don't know. Maybe? But the thing is, it doesn't feel like it'd be much of an upgrade; bear in mind you'll have to replace your motherboard, CPU, RAM, and re-install (possibly also re-license) Windows.
    4690k vs Ryzen 5 3600 - the 3600 isn't much more than the 2600 but actually makes a real difference
    https://cpu.userbenchmark.com/Compare/Intel-Core-i5-4690K-vs-AMD-Ryzen-5-3600/2432vs4040
    This site doesn't have a benchmark for the new Zen 2 Ryzen 7 chips. You can bet that the next bump up would be even better.
    I'd suggest if you want Ryzen that you should be absolute minimum of the 3600, and you might want to go to the next one up after that.
  19. Jeff Hine
    8 May 2009
    How the heck are 4790K's commanding the prices they are, 2nd hand...?
    If Devil's Canyon are worth the resale prices some are asking for them, it must purely be me that has NFC what they are capable of and/or how to get the best out of them; just goes to show that the kit and the user need to be on the same level (not mine) to get the best out of them.
  20. Zoon
    12 Mar 2001
    4790k - 4.0ghz, quad core, hyperthreading, turbo boost to 4.4ghz - passmark 11172
    6700k - 4.0ghz, quad core, hyperthreading, turbo boost to 4.2ghz - passmark 11107
    7700k - 4.2ghz, quad core, hyperthreading, turbo boost to 4.5ghz - passmark 12033
    Granted the 7700k is getting really rare now as we're on 9th gen, but it's still available new for around £300-£350 (amazon). Now, note how close all both the 6700k and 7700k are in performance to the 4790k, and then add in the fact you gotta bin off your motherboard and RAM for DDR4 and I guess it makes sense!!
    There's been a couple of them on these forums for much more reasonable prices than the £170 that CEX are asking with a year's warranty though, and your 4690k for trade-up combined with your £400 budget are what makes this option worth considering.
    So given I've been pretty pro "Upgrade that bugger, mate!" I guess I should price up the alternative Ryzen upgrade. I'd really honestly wait for July 7th and for the Zen 2 stuff to come out. You want to be looking for the 3700X in my opinion, which should be around £260.
    Allow £100 for a motherboard, £80 for 16GB of DDR4, and probably a new heatsink, you should be fine with a be quiet! Pure Rock Slim which is rated to 120w TDP so plenty for the 65w TDP on this chip.
    3700X - £260
    X470 motherboard - £100
    16GB DDR - £90
    be quiet Pure Rock Slim - £20
    Subtotal £470
    Sell your bits on these fine forums for approx (you might take a bit more, allowing for shipping inclusive/worst case costs etc based on above)
    4690k - £50
    Motherboard - £60
    RAM first 2x8GB set - £45
    RAM other 2x8GB set - £45
    So that's potentially £200 back towards your Ryzen upgrade. If you can tolerate being without your PC while you sell, you might be able to treat yourself to the 3800X which is going to be about £50 more - and you will still pocket around £80 back, or you could spend ALL of it and get the top whack Ryzen 9 3900X!
    Ryzen 7 3700X - 8 cores, 16 threads, 3.6ghz, boost to 4.4ghz
    Ryzen 7 3800X - 8 cores, 16 threads, 3.9ghz, boost to 4.5ghz
    Ryzen 9 3900X - 12 cores, 24 threads, 3.8ghz, boost to 4.6ghz
