Cases What would you like to see from BitFenix?
Discussion in 'Hardware' started by stulid, 16 Jan 2014.
  1. pete*
    pete* Something witty here.
    29 Apr 2009
    I
    Thanks for the update!! :) :rock:
    Looking good, gonna have to get saving now.
    Any chance you knowing if scan will be stocking them
    and (roughly) when?
    I'll echo Damien's comment also - assuming he means different
    coloured cables to use. Would be cool to be able to buy other colour
    cables to plug directly into the PSU (32pin obv not). :D
    Preferably not at exorbitant prices like corsairs cable kits. :/
  2. stulid
    stulid What's a Dremel?
    30 Jun 2011
  3. Impatience
    Impatience Minimodder
    6 Apr 2014
    What would I like to see from BitFenix? A SFX equivalent of the Corsair CXM430M (Semi-Modular 430w Power supply) and a case that accepts it with an ITX mobo, 2-slot GPU (as noone makes single slots anymore, it seems?) and a 120mm AIO. That with 2x SSD mounts, or 1x SSD & 1x 3.5" HDD and a slim Blu-Ray is the perfect system! If you can fit that in a 15L or so case, you have my money.. With or without a window!
  4. urobulos
    urobulos Minimodder
    13 Apr 2010
    The cables on the PSU look nice, shame that judging from early reviews, the PSU itself is average at best. Oh well, Cooler Master V850+ Bitfenix or NZXT extensions for me.
  5. screamatme
    screamatme What's a Dremel?
    28 May 2014
    Would love to see soft-touch front panels with no drive bay cut out. For a sleek and clean customization with no effort.
  6. fev
    fev Industry Fallout
    13 Aug 2003
    Small case, with room for 8-10 3.5" HD's.
    My beef is having to run a media server in a case the size of a small child.
  7. Parge
    16 Jul 2010
    SO MUCH THIS! (apart from the OD, which for me isn't necessary)
  8. Impatience
    6 Apr 2014
    I wouldn't care if they just left a gap for one and had screw holes for one, but didnt cut out the front of the case for it! Just having the option of easily modding one in would make the perfect case for me!
  9. stulid
    30 Jun 2011
    So I thought I would bump this.
    We now have Phenom vented side panels available in both black + white, these have seen some good gains iin VGA card temperatures.
    If you guys can think of anything else you would like to see then fire away.
