Other what would you upgrade.
Discussion in 'Hardware' started by dave_c, 16 Aug 2012.
  1. dave_c
    dave_c Minimodder
    31 Jul 2009
    ok so you can see what i have in my signature. iv been out of the game for some time so please forgive me if im a little behind.
    iv got £3-400 to upgrade could probably get a little more if i tried, im thinking SSD but wanted a few more opinions, im pretty sure the WD HDDs are the major bottle neck in my system. however i think the really high end SSDs might just reverse the bottle neck so dont think its worth getting the super powered ones.
    this is what im thinking anyway.
    X1 SAMSUNG 830 SERIES SSD 256GB DESKTOP KIT INC NORTON GHOST Slim 7.5mm
    http://www.scan.co.uk/products/256g...e-mcx-nand-flash-read-520mb-s-write-400mb-s-p
    X2 Samsung HD204UI 2TB Spinpoint F4 Hard Drive SATA II 3Gb/s (cloned)
    http://www.scan.co.uk/products/2tb-...ii-5400rpm-end-of-life-sata-iii-better-option!
    this comes to a total of about £310 so there is a good amount of space for play. gutted that my MB only supports up to sata 2 im assuming if you plug sata 3 devices into a sata 2 mb it will just slow down to sata 2 standards and will still work. please do correct me if im wrong.
    any advice greatly appreciated
  2. Blogins
    Blogins Panda have Guns
    3 Aug 2010
  3. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Yeh, a SATA 3 device will just run as SATA 2, but that means when you get a new motherboard you'll get another speed boost. Even on SATA 2 you'll still see the difference, I did with my old X25-M's and that was on a C2Q system...
  4. dave_c
    dave_c Minimodder
    31 Jul 2009
    to be entirely honest i could put my grand mothers reading glasses in my PC and would probably see a speed increase :D
    my current drives are eco drives and have terrible read write speeds :).
    so is it a good plan on what to buy, or would i be better getting a new/another GC instead? or something like that? thanks for the information, appreciate it.
  5. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    Unless you are really short on storage space, I wouldn't bother with the hdds. If it was me I would rather spend the money on ssd and gpu update, if you game, since you are a couple generations back. I have a similar spec system and it is perfectly fine for me still, though a gtx670 is next on my to do list. I won't even be thinking about upgrading my core system until after Haswell parts are out next year.
  6. Ivoryspike
    Ivoryspike Air Cooled
    11 Jan 2010
    Here's the link to the scan equivalent Samsung 830 @ £149.10. *
    Been looking at upgrading my existing 1TB Hdd's to 2TB myself but waiting for them to come down to pre flood prices (£55 i think). I might just wait for a deal on some 3TB HDD's now though, it depends on how much space you need.
    edit: *or if you order today / tomorrow morning it's on the today only page for a couple of quid cheaper.
  7. dave_c
    dave_c Minimodder
    31 Jul 2009
    It's not so much the hd space that the issue, they are all very slow and the one I use for windows is starting to show signs of failure. I keep all software on my win drive but NOTHING else. So it's not really even been acting as a scratch disk (I think that's the correct term). The others however have been wiped and reused A LOT so I'm worried they aren't too far behind. I'm talking a couple of gig being written and wiped every day.
    I'll look into getting some more cash for a new PSU and gpu (not sure 550w will cut the new hardware) who is the leader atm for gpus?
  8. dave_c
    dave_c Minimodder
    31 Jul 2009
    that says its the notebook version, is that a good thing (lower power usage [i assume]) or a bad thing (slower speed [also i assume])
  9. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    It's the exact same drive -- it just comes with different accessories than the "desktop" version.
  10. dave_c
    dave_c Minimodder
    31 Jul 2009
    have ordered, thanks for the help.
  11. Blogins
    3 Aug 2010
    Don't forget your cashback!
  12. dave_c
    dave_c Minimodder
    31 Jul 2009
    lol, no chance, im a penny pincher :D
