Cases what you think of The coolermaster cm 690 nvidia edition??
Discussion in 'Hardware' started by Chriscogley, 23 Aug 2011.
  1. Chriscogley
    Chriscogley What's a Dremel?
    13 Jul 2011
    I am a new pc enthusiast and i am thinking of buying the coolermaster cm690 nvidia edition and i wanna know what all of the community know about it of think about it??
    would like as much advise as possible please thankyou[​IMG]
  2. fdbh96
    fdbh96 What's a Dremel?
    29 May 2011
    I it basically a 690 with a custom finish for +£20. if so you would b better off with another gaming game. NZXT phantom?cm haf x?
  3. Chriscogley
    13 Jul 2011
    i will be able to get the case cm690 nvidia for £60
    is that any good?
    also do you know if the can be water cooled?
  4. OCJunkie
    OCJunkie OC your Dremel too
    19 Apr 2011
    The 690 II A is a nice case, very satisifed with mine and I recommend it. Though I gotta say the Nvidia edition is kinda tacky, all bright green and crap...
    For WC it can fit two 220's or maybe even 240's right out the box, one in the top the other in the bottom. Not a huge case so tight fit but the mounting points are there.
  5. Chriscogley
    13 Jul 2011
    can i ask you to get a pic of the cooling and how it is mounted if that isnt to much hassle please?
    but for 60 quid it's a good starting case you think?
  6. Bede
    Bede Minimodder
    30 Sep 2007
    It often goes for a quid or two cheaper than the standard and white editions.
  7. Sentinel-R1
    Sentinel-R1 Chaircrew
    13 Oct 2010
    Whilst there's no accounting for taste, the 690 is a very capable case for both air and water-cooling alike. The colour choice is up to you buddy.
  8. OCJunkie
    19 Apr 2011
    Chriscogley I have no pics for you sorry as mine's not WC, I was just saying what's possible to put it in without modding anything. You'll see for yourself if you get it it's pretty self-explanatory, and there are plenty of builds archived just run a search through the work logs for examples.
  9. Chriscogley
    13 Jul 2011
    okay thankyou mate
    i was given a log by another guy on here called 23RO_UK and it is amazing
    it is the same case as mine and he has got dual rads in there and it is an epic build
    thankyou anyway you guys are all so helpful on here
