Other What's a great office chair?
Discussion in 'General' started by AlexB, 1 Nov 2011.
  1. AlexB
    AlexB Web Nerd and WC Addict
    22 Dec 2005
    What do you guys rate as a great office chair, for perhaps £250?
    Fed up of having an aching back after a day in the office.
    Ta
  2. 3lusive
    3lusive New Member
    5 Feb 2011
    I use the Markus from Ikea, about £125. Good back support, height adjustable and very comfy. Had it for about 9 months and its doing fine
  3. AlexB
    22 Dec 2005
    My current one is an Ikea one, and it creaks and what-not.. will add it to the list of ones to consider though, and we're there tomorrow by chance so will try one out
  4. Nexxo
    23 Oct 2001
    The Aeron by Herman Miller.
    Bought new they are definitely outside of your budget (and mine), but luckily there is a teeming trade in used chairs because they are so popular. Pick one up at eBay for less than £200,-- if you shop around. Get the "Size B". Size A is for petite girlies and Size C is for big phatties.
  5. LennyRhys
    LennyRhys Oink!
    16 May 2011
    I'm also in the market for a new chair... the Aeron looks amazing, so size C it is.
  6. Nexxo
    23 Oct 2001
    Check the chart here to see if your frame is ample enough...
  7. AlexB
    22 Dec 2005
    Thanks mate. We actually had them at an agency I worked at many moons ago, will check them out.
  8. longweight
    7 May 2011
    I got my Ergohuman from eBay for £275, full leather and headrest :D Love it.
  9. MeddlE
    MeddlE Norwegian Blue
    23 May 2011
    Another Ikea Markus user here. Got mine in June 2010. A couple of weeks back the piston started playing up, 5 days later a brand new Markus delivered to the door and the old one taken away. 10 year no quibble warranty. Fantastic service from Ikea and a really comfortable chair too.
  10. Nexxo
    23 Oct 2001
    Ikea makes surprisingly awesome stuff when it comes to human comfort. Their matrasses are second to none. I recommend an Ikea bed to anyone.
  11. Da_Rude_Baboon
    Da_Rude_Baboon What the?
    28 Mar 2002
    They are European sizes though so you can only use IKEA mattresses. Normal UK ones don't fit.
  12. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    aww im well in C country!
    Edit; oh! I read it wrong, I am B or C! thats a relief, Im not a big phattie! :D
  13. thehippoz
    thehippoz New Member
    19 Dec 2008
    everytime I see margos name in the list of new posts.. I have flashbacks to bilbo
  14. Zoon
    Zoon Hunting Wabbits since the 80s
    12 Mar 2001
    I also use one of these chairs daily at home, and my work chair is a Herman Miller Aeron.
    Both are comfortable, however on the occasions I have a bad back, the Markus is way more comfortable.
    I also like the extra height on the Markus, it supports your head when you lean back. The Aeron I have does not.
  15. Margo Baggins
    28 May 2010
    wtf did you do to bilbo!?
    LennyRhys likes this.
  16. penryn 2 hertz
    penryn 2 hertz I'm not a science fiction writer...
    10 Jun 2010
    Bilbo sounds like a vibrator
  17. LennyRhys
    LennyRhys Oink!
    16 May 2011
    Yeah I'm the same, 6' and 200lbs so B/C is good. Off to ebay I go... :clap:
  18. penryn 2 hertz
    10 Jun 2010
  19. Orca
    Orca New Member
    2 Dec 2005
    Ikea Markus owner here as well, although at work we use the Aeron. Personally I prefer the high back so I can rest my head a bit :p
  20. Margo Baggins
    28 May 2010
    there is so much wrong there haha
