Electronics What's an inverter: Cold cathode
Discussion in 'Modding' started by bee2643, 2 Apr 2002.
  1. bee2643
    bee2643 What's a Dremel?
    7 Mar 2002
    k
    i took a cold cathode bulb out of my scanner, and the thinger it plugs into but im not sure if its an inverter or not (because apparently u NEED it to run :p
    this is what it looks like
    now, how would i go about hooking this upto my case? 12v or 5v?
  2. KevinOwns
    KevinOwns What's a Dremel?
    13 Jan 2002
    That looks like an invertor. And it would probably be 12v.
  3. Yo-DUH_87
    Yo-DUH_87 Who you calling tiny?
    6 Mar 2002
    look at the adapter the scanner used to plug into the wall, if it said 12v, you're good! If there is no adapter, that scanner was doomed when you bought it :lol:
    Signing out...
  4. bee2643
    7 Mar 2002
    wholey booyow batman
    its a 12v inverter and i LOOVE it :lol:
    its the whitest light ive ever come across :eeek:
  5. Yo-DUH_87
    6 Mar 2002
    Nice! I have an old junker scanner I want to do this too! :hehe: POWER!!
    Signing out...
  6. scoob8000
    scoob8000 Wheres my plasma cutter?
    17 Feb 2002
    NO COMMENT :hehe:
  7. bee2643
    7 Mar 2002
    is it possible to hook 2 cold cathodes upto 1 inverter
  8. KevinOwns
    13 Jan 2002
    Bee, I don't beleive you can do that. There have been numerous posts about it and the general feeling is that you need two. I suppose you could rig up a switch so that only one is on at a time if you hooked two up to one inverter, that might work.
  9. Yo-DUH_87
    6 Mar 2002
    I don't think that the designers of that scanner designed that inverter to stand the power of that cc!
    You could probibly design one, but almost every cc you buy comes with one.
    Signing out...
  10. bee2643
    7 Mar 2002
    heh, ive got this whole board thinger here that the cc plugged into, but its got the lens and other **** for the camera, as well as the camera itself on the board, and onna those ribbons just plug into it, if i can determine +ve from -VE on the ribbon i could get it to work with its own inverter couldnt i?
  11. Yo-DUH_87
    6 Mar 2002
    It probibly could run on it's own inverter, but I think you would be better off with what you're using!
    Now, come here, my little elderly scanner, you have peices I desire...
    Signing out...
  12. bee2643
    7 Mar 2002
    uhh
    i have 3 cold cathode bulbs, all jacked from scanners, one has an inverter, and one of them has a inverter built into the board...the board is about 1.5"x5" and i dunno where +ve and =ve are for a ribbon connects to this board, how do i go about finding out?
  13. Yo-DUH_87
    6 Mar 2002
    I don't think that you could use one inverter for all that. I know an engineer, and you want it to barely work. As my wise father says, anyone can build a bridge, only an engineer can build a bridge that barely stands!
    Man, I just threw away that dead scanner! Darn, knew I should'a kept it!
    Signing out...
  14. bee2643
    7 Mar 2002
    me thinks yo-duh needs to read posts more carefully
  15. Yo-DUH_87
    6 Mar 2002
    Oops, sorry. Didn't get much sleep last night :lol:
    How was it hooked up? What you do, is you take a voltmeter, and set it to beep if it detects a short. You stick one lead on the in voltage from the wall outlet, and start probing the contacts with the other (with the scanner unplugged from the wall, of cource).
    If that is what you man by +ve and ve, this should work. If not, let me know (and I'll whack myself on the head again to spill out the awnswers).
    Signing out...
  16. viridius
    viridius What's a Dremel?
    7 Apr 2002
    Insulate those leads. They are at least 100 volts. One thing to help, ground traces are usually the large ones.
  17. Yo-DUH_87
    6 Mar 2002
    Once again, you're right. I know neon inverters are about 115, and ccs are prety similar, I think.
  18. scoob8000
    17 Feb 2002
    actually i did some checking, the usual CCFLs weve been putting in our cases have something around a 1,200 volt startup, and around 600-1000 operating range.. seems to be about average..
    just tested my research.. a little above what ive read..
    brings me to my question, i cant locate this kynar wire, nor can i find anything suitable for that voltage, best i can do is 600volt wire, but what would be better for less leakage, solid or stranded?
    -scoob8000
  19. Yo-DUH_87
    6 Mar 2002
    Leakage? I think solid is what they use for the mains in your house, so gust get thick solid wire (16-12 g), and that should do it!
    Signing out...
  20. bee2643
    7 Mar 2002
    so i need special wire to connect the inverter to the ccd
