Electronics Whats name of pin housing?
Discussion in 'Modding' started by bluc, 20 Feb 2014.
  1. bluc
    bluc What's a Dremel?
    4 Apr 2012
    Whats The name of the single crimp pin and housing that goes onto the front panel header on the motherboard. Can find three pin fan hosing and crimps and 4pin molex but none of the single crimps and housing. Anyone know the proper name?
    Sent from my Nexus 7 using Tapatalk
  2. Big Elf
    23 Apr 2009
  3. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Looks like you're planning to do what I did over xmas.
    Replace all those single connectors with one for all.
    This is where I got mine:- Relchron @ Amazon
  4. bluc
    4 Apr 2012
    Building arcade cabinet and need the single ones thanks for the links!!:dremel:
  5. bluc
    4 Apr 2012
    Wondering the metal crimp pin is it the same as the one used in 3 pin fan housing's?
  6. IanW
    IanW Grumpy Old Git
    2 Aug 2003
  7. bluc
    4 Apr 2012
    OK thanks again
