Other What's ruining your life right now?
Discussion in 'General' started by TheMusician, 28 Oct 2009.
  1. The_Crapman
    The_Crapman Don't phone it's just for fun.
    5 Dec 2011
    I think the bigger issue is the low fan speed and GPU usage.
    @Smellyhead, have you tried setting a manual fan curve? If you can get the fan speed sorted, try running one of the heaven benchmark on max settings to see if the gpu usage is still limited to that. Also, did you do a clean driver install after putting in the new card?
  2. Vault-Tec
    30 Aug 2015
    Bollocks ! :hehe:
    The_Crapman likes this.
  3. Vault-Tec
    30 Aug 2015
    Took out my new bike. Chain decided to snap. Pain.
  4. goldstar0011
    goldstar0011 Well-Known Member
    2 Sep 2007
    Parking ticket whilst going to Hospital, used to live on the same road I parked on, didn't notice the really small sign about resident badges only until I returned.
    Probably would have got a ticket in the car park, 2.5 hour delay to get x-ray and doctor to say, we need you to come back again
  5. Gunsmith
    Gunsmith Maximum Win
    23 Sep 2005
    suns's gotten to my ATV cover and weakened it. bloody thing ripped as i was taking it off to clean the bike.
  6. legoman
    legoman breaker of things
    28 Feb 2010
    Management "you now support all apple products"
    Me "wait, wut?"
    Management "go fix"
    Me "how I dont have any accounts"
    Management "BUT FIX"
  7. The_Crapman
    5 Dec 2011
    Re-felting the shed roof this afternoon I forgot to put some gloves on before slopping the glue about. Half an hour of scrubbing and removing of skin later....
  8. Scroome
    Scroome Well-Known Member
    26 Apr 2011
    If the Mrs (or you..:grin:) has any nail polish remover, that'll do the trick nicely.
    If all else fails, the fumes will make you not care anymore....
    MLyons and The_Crapman like this.
  9. The_Crapman
    5 Dec 2011
    Yeh I tried that, but there's so many cuts and grazes it stung to buggery. Her makeup wipes were quite successful and got me that far, but can't get into my prints and under nails. Was going to try TIM cleaner but can't find it now and I know I've had it recently :rollingeyes:
  10. RedFlames
    23 Apr 2009
    IIRC WD40 or similar will get that stuff off. Assuming it's bitumen type goop. Some say olive oil or baby oil too.
  11. David
    David Take my advice — I’m not using it.
    7 Apr 2009
    Isopropyl alcohol will shift it too, so will orange oil, with a teensy bit more added sting. :D
    Man up and take it like a champ!
  12. adidan
    25 Mar 2009
    Either of these should work. WD40 will probably work out cheaper :)
  13. The_Crapman
    5 Dec 2011
    Come on Dave, we all know I'm no champ. Just a punk-ass chump.:eeek:
    I've got some wd40 so will give that a blast. If nothing else it'll stop my knuckles squeaking.
  14. veato
    veato I should be working
    15 Jan 2010
    iMac has dies and this time I fear it's beyond economical repair. Added to the fact I'm not in a position to replace it anytime soon I think my ability to edit photos and do a bit of light gaming is about take a hit.
  15. Byron C
    Byron C No liability accepted as a result of this post
    12 Apr 2002
    WRONG - WD40 is not a lubricant. You want some proper oil to stop those squeaks, or grease if it's a heavy-duty joint.
    Just trying to help :thumb: :grin:
  16. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Work's Office 365 (I know!) keeps asking me to sign in with 2FA every 30 seconds because it's lost the password server.
  17. The_Crapman
    5 Dec 2011
    FTFY :hehe:
    Also....
    :grin:
    That last one though :eyebrow:
  18. Gareth Halfacree
    Gareth Halfacree WIIGII! Staff Administrator Super Moderator Moderator
    4 Dec 2007
    Absolutely this.
    My wife said her downstairs parts stung for a week.
    Thank you, thank you, tip your waitress, try the veal.
    Vault-Tec, Byron C, David and 3 others like this.
  19. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Fixed Office - I tried turning it off and on again. :D
  20. Mr_Mistoffelees
    Mr_Mistoffelees The Lunatic on the Grass.
    26 Aug 2014
    When my mechanism gets sticky, a good scrub with a nail brush when in the shower, usually sorts it out.:grin:
