Other What's ruining your life right now?
Discussion in 'General' started by TheMusician, 28 Oct 2009.
  1. legoman
    legoman breaker of things
    28 Feb 2010
    We have a great laser printer at work Toshiba swear blind is fine, it print, but the fuser module doesn't hit the right temp so you can rub off said toner leaving slightly seared imprints in the paper.
  2. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    Hybrid environments with legacy public folders.
    And **** internet so I can't just mass-migrate everything over a weekend and stop working on this dumbass problem.
  3. Gareth Halfacree
    Gareth Halfacree WIIGII! Staff Administrator Super Moderator Moderator
    4 Dec 2007
    What you've got there is the world's weediest laser etcher!
    legoman likes this.
  4. Jeff Hine
    Jeff Hine Nothing special
    8 May 2009
    Might be cheaper to buy a new printer...
  5. Behemoth
    Behemoth Timelord in training
    1 Nov 2001
    Signed off sick from work for two months, had an operation on my right arm to stop it dislocating. I was first told by the surgeon I'd be signed off for four weeks, which we as a family can almost cope with. Sadly he handed me my sick note when I was leaving the hospital and it said two months, and off her jolly well trotted. That takes us pretty much up until the new year, Statutory Sick Pay is going to be interesting.
  6. Gareth Halfacree
    4 Dec 2007
    Eef. At least you qualify for SSP, tho': as a freelancer, if I'm off sick I get nowt. That's why I still haven't booked in the operation I need on my hand...
  7. legoman
    28 Feb 2010
    I may get some really crappy 80gsm paper in see what it does
    Isn't that usually the case with inkjets? Printer with ink costs £30, new cartridges cost £40. To be fair I have been using non brand ink in my Canon for years, £15 for a full set of six inks isn't bad.
  8. The_Crapman
    The_Crapman Don't phone it's just for fun.
    5 Dec 2011
    Detached rotator cuff by any chance? I had that operation 12-13 years ago and have not had a dislocation since and I could barely keep my arm in in the month leading up to the op. Depending on your job, you might be OK to go back on light duties 4-6 weeks after. I was VERY lucky to be in a job with full sick pay at the time so took the full 2 months, but I could have gone back after 4 I recon and done everything left handed (desk job), which I had got quite good at by then.
  9. Mr_Mistoffelees
    Mr_Mistoffelees The Lunatic on the Grass.
    26 Aug 2014
    Waiting until the underlings, sorry, children are able to do your work for you, while you recover?
    IanW and Gareth Halfacree like this.
  10. Behemoth
    1 Nov 2001
    I'm not sure exactly what the cause was, each time I dislocated it according to the surgeon who showed me the result of my MRI scan said the soft tissue was damaged each time. Also the little ball that goes into the socket was also damaged, hence why it would just dislocate. The last straw was in April when my arm popped out when I was sleeping and that point I thought this is getting silly, I've had this problem off and on 6 times so something has to be done, so here I am today.
    I am doing as much physio as I can during the day, I'm being told I'm going to need the sling for four weeks, I want to be out of it by the end of next week.
  11. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Don't do more exercise than your physiotherapist tells you. It'll just make it worse!
  12. The_Crapman
    5 Dec 2011
    Sounds different to mine then, as for me the cartilage cup of the joint has detached from the bone. I'd dislocated it in bed a few times, including one 'amusing' tale of when I was home alone, on my back, arm dislocated pointing up about 20 degree angle between my arm and head, unable to move, no one due back for about 9 hours, alarm on my phone blaring. After a while I managed to maneuver enough to get my phone off the floor with my feet, fling it up and arrange a rescue. It was about 3 hours from dislocation to the ambulance getting there.
    As Ian said, don't go pushing it too soon or you'll undo whatever they've fixed. I wouldn't do any physio for the first week besides gently maneuvering it, holding it with your left hand to support most of the weight, stop it getting stiff. And keep it in that sling and keep it supported!
    Speak with your work about how they can support you. Light duties, phased return etc. They'll probably be keen to get you back asap too and will help, but don't rush back and hurt yourself.
  13. Byron C
    Byron C Probably isn't Hitler, but definitely a muppet
    12 Apr 2002
    For inkjets, this is true.
    However I have a colour laser printer :thumb:
  14. legoman
    28 Feb 2010
    Well, in that case your cyan is low so you cannot print black and white.
  15. bawjaws
    bawjaws Well-Known Member
    5 Dec 2010
    Aye, but printers typically ship with ink cartridges that are a fraction the capacity of the standalone ones. Bit like battery-powered toys that come with batteries "for demonstration purposes only" that go flat in 5 minutes!
  16. Zoon
    Zoon Hunting Wabbits since the 80s
    12 Mar 2001
    I have a Dell E525W, wireless colour laser printer, scanner, copier, fax. The compatible toners I use are around £30 for a full set of four. I’ve been very happy with it over the last couple years!
  17. Byron C
    12 Apr 2002
    Out of interest where do you get them from? Always useful to know trusted brands/retailers.
  18. Zoon
    12 Mar 2001
    Amazon :D
    Byron C likes this.
  19. The_Crapman
    5 Dec 2011
    It's truly disgusting the stuff you can get on amazon for cheap. Even their coffee is decent and at £2 a brick, a bargain.
  20. Gareth Halfacree
    4 Dec 2007
    Tell a lie, must have had draft mode on - still flashing the "black toner low" light, still printing!
