Other What's ruining your life right now?
Discussion in 'General' started by TheMusician, 28 Oct 2009.
  1. Pete J
    Pete J Employed scum
    28 Sep 2009
    Not interested in excuses. Think of it as a little bit of extra exercise.
    I'll also make a note to bring my welding kit on future excursions. Let's see if your toolbox can sort that out :p: .
    David and perplekks45 like this.
  2. lancer778544
    lancer778544 Multimodder
    5 Jan 2011
    Pete J likes this.
  3. mrlongbeard
    mrlongbeard Multimodder
    31 Jan 2010
    I like a challenge
    Only after I've had a few brews
    Pete J and Mr_Mistoffelees like this.
  4. Byron C
    Byron C Official Necromancer
    12 Apr 2002
    Fingers66, IanW, Pete J and 2 others like this.
  5. Goatee
    Goatee Multimodder
    19 Apr 2015
    Zip ties?
    One of these instead.
    Chuck the key down the nearest drain. Best £7 you will ever spend...
  6. lancer778544
    5 Jan 2011
  7. mrlongbeard
    31 Jan 2010
    Devious, that'd need a trip back into the store to pick up a felt tip pen to defeat, or just break out the car jack
  8. play_boy_2000
    play_boy_2000 It was funny when I was 12
    25 Mar 2004
    That's a home depot cart - about the worst possible store to do that at, unless your only goal is only costing them ~$15 in tool rental fees (or $9 for a hacksaw and a bit of elbow grease).
  9. Mr_Mistoffelees
    Mr_Mistoffelees The Rotary Cat.
    26 Aug 2014
    I had a Citadel lock, one of the earliest versions of that kind of bike lock. When I had given up cycling, I tried to see if a hacksaw would do anything to it. Took a little of the protective plating off...
  10. play_boy_2000
    25 Mar 2004
    Naturally the good locks with proper hardened steel will make a mockery of a hacksaw, but nothing stops an angle grinder.
    Mr_Mistoffelees likes this.
  11. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    Ruining? Yes. Because I looked up those cards on Fleabay..
  12. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    My job. Yes, I only started in May and yes, I know I should give them more time, but I'm almost ready to hand in my resignation. The customer I'm responsible for is a double-faced, lying, lazy, and ridiculously pushy arsehole. The company I work for is about as well-organised as Boris Johnson's hair, and overall I feel left alone to pick up the pieces and work myself to a hospital bed. I am paid very well, but this is something I don't care for and might just pull the plug on.
  13. Pete J
    28 Sep 2009
    The job before the one I got made redundant, I was already looking for a new job within 3 months but ended up being there for over a year - I wish I'd left sooner.
    perplekks45 likes this.
  14. lancer778544
    5 Jan 2011
  15. mrlongbeard
    31 Jan 2010
    Overclockers.co thinking I'm using a bot or auto-refresh script, and require me to raise a ticket on their forum (so join their forum) to have the restriction lifted :eyebrow:
    Erm, how's about no, sod off, jog on etc etc etc, I shall go elsewhere for my parts thank you very much, howabout you fix your website you might lose less sales. :jawdrop:
    FFS, I've just had an unexpected £1.3k dropped in my lap, have poor impulse control and fancied a new precious.
  16. Almightyrastus
    Almightyrastus Rule #9
    21 Mar 2002
    I feel like crap. Awake on and off all night, sweating like crazy, too hot with covers on, too cold without. Feel proper sick, head is feeling all woolly. If I had been going into the office today, I would not be going into the office today.
    Had a shower, and trying to nibble on sommat to eat, lets see if that does owt to help things.
  17. Byron C
    12 Apr 2002
    Time for the car's MOT and service. Got there at 8am and we were told roughly 3-4hrs to do both.
    MOT Fail: Rear offside coil spring snapped. That's pretty bad, so go right ahead...
    But....
    All four brake discs are worn and lipped... And the pollen filter needs changing... And the coolant needs flushing and changing... And the brake hydraulics needs flushing and changing...
    And the car is supposed to be cheaper to maintain than my ST1300A Pan European bike....
  18. mrlongbeard
    31 Jan 2010
    Go buy a Haynes manual.
    They do that, but unless below minimum thickness it's perfectly normal, and unless you've got OEM honda cheese discs they'll go for 100,000 miles +
    Normal consumable item, stops your air con getting smelly, and normally only a tenner
    It'll survive without that, but if following the owners manual to the letter nothing that can't be done in five minutes with a hose pipe.
    Y'know that's one job I've never, ever done on any vehicle, except for topping up after a wee bleed down when changing pads.
    Unless you're needing to keep a warranty intact of course, in which case you've gotta suck it up
  19. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    It used to be a lot easier when you could buy ATE super blue; sitting watching a yellow fluid change to another, slightly lighter shade of yellow isn't easy.
  20. Byron C
    12 Apr 2002
    I have neither the time, the tools, the working space, nor the inclination to start learning to do this stuff myself.
    Working on the bike? Yeah, absolutely - bring it on! In fact I do plan to get the Haynes manual for my bike! On the car however? Nah, I'm good thanks. I know I'd save a fortune on labour costs, but that saving is offset by the fact it'll take me three or four times as long to do the same job because I don't know what I'm doing.
    Getting all this stuff done is fine, it's not a problem - it's all wear and tear type stuff that's going to need to be done eventually. The problem is when it all comes at the same damn time! We got the service and MOT done at the dealer we got the car from, because they had an offer for free MOT tests. But they are ridiculously expensive so we're gonna get a second opinion from a trusted local garage.
