Other What's ruining your life right now?
Discussion in 'General' started by TheMusician, 28 Oct 2009.
  1. ModSquid
    ModSquid Multimodder
    16 Apr 2011
    EDIT: totes misunderstood. Apologies Mr L
  2. Arboreal
    21 Jan 2011
    RIP Oddball
    IanW likes this.
  3. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
    Many hours spend last night troubleshooting my Server only to find this when changing CPU's:
    No idea how it happened unless it was always like that and has only just failed. Whole machine turned off whilst I was idle in the bios checking something out (remotely). Tried everything I could find online and all the normal troubleshooting steps but nothing made a difference (Bios Reset, Multiple PSU, different RAM, re-seated CPU, In/out of case etc). No post to VGA or PCI-E GPU and will not start via IPMI. Board is getting power but the socket itself appears to be dead.
    Need to have another look today with better light but a quick glance with a magnifying glass looks like is not recoverable with my tools / eyesight (the pins are sooooo small compared to LGA 1150/1200).
    Now I either need to source another SP3 Epyc board or bite the bullet and "upgrade" to a Threadripper build (or sidegrade / switch to a full blown blade server).
  4. Byron C
    Byron C asphinctersayswhat
    12 Apr 2002
    Oof… That looks like a dense set of pins, not sure I’d take that on either…
    Is it worth seeking out a replacement board?
  5. Pete J
    Pete J Employed scum
    28 Sep 2009
    Left my effing rucksack at home this morning (I work away from home during the week). That means no laptop to play Netflix, YouTube etc in the evenings.
    Also, my lunch for today is probably going to be pretty ripe when I get back to it on Friday.
  6. ModSquid
    16 Apr 2011
    Being on a tech forum (and yourself being a bit handy) I'm sure you know this, but when a penknife blade won't do it, apparently one of those mechanical pencils will. Push/pull the lead out of the metal tip and use it as a socket of sorts to coax the pin back into place, so I'm told. Not actually tried it myself as the penknife has always sufficed, but might work if you've a steady hand...?
  7. xaser04
    27 Jun 2008
    I can't find exact replacements on Ebay but they are north of £300. Whilst cheaper than a Threadripper replacement build I am on the fence whether I would want to spend that much just for a replacement (especially when the device is not mission critical).
    Yep, repaired a number of LAG sockets over the years, most recently a LAG 2066 but this thing is something else when it comes to the size of the pins, at least to my eyes (they look somewhere around half the size of the pins on LGA 2066 but much tighter spaced). I will borrow the magnifying glass I have at work (not a hand held one which is all I have at home) to see if I can get anything into the gaps between pins. Worst case I completely knacker it but its already presenting as knackered anyway sooo...
  8. ModSquid
    16 Apr 2011
    Let me know if you want an extra pair of hands/eyes on it... You do postage and I'll give it my best OCD attempt, no guarantees, "all else fails" option.
    adidan, Arboreal and xaser04 like this.
  9. mi1ez
    mi1ez Modder
    11 Jun 2009
    What have you got to lose by trying? An already dead board? Go for it!
    xaser04, adidan and Byron C like this.
  10. xaser04
    27 Jun 2008
    Well I successfully managed to fix the pins using the magnifying glass from work but sadly no dice. Barring the CPU fan spinning and BMC kicking into life the board otherwise shows no sign of life. Power LED (LED1) isn't lit suggesting something amiss with power. Currently have it on my test bench with a known working PSU thus I know it isn't that. CPU is also cold after 10 mins of the board being "on" further suggesting no power at all, at least not on the 12v line.
  11. IanW
    IanW Grumpy Old Git
    2 Aug 2003
  12. Pookie
    Pookie Illegitimi non carborundum
    4 May 2010
    I thought my life sucked until I read the last few pages of this thread! But seriously I wish all those fighting health issues be it themselves or friends and family a positive outcome.
    Isitari, Pete J, IanW and 3 others like this.
  13. ModSquid
    16 Apr 2011
    Hold tight - it's not the CPU that's died, is it? Have you got a spare or can someone sub you one for testing?
  14. xaser04
    27 Jun 2008
    Yep tested with both the 7551 and 7402 Epycs (both known working before the issue started - unless they have both died as well). Also tested with different kits of RAM in different slots.
  15. ModSquid
    16 Apr 2011
    Balls. And the PSU definitely powers up a different board using the 8-pin lead?
  16. BazzUK
    BazzUK Are we there yet?
    6 May 2024
    Appendicitis, had surgery first thing this morning (around 12 midnight) after being rushed in yesterday morning
  17. Arboreal
    21 Jan 2011
    That's rough, hope you recover quickly
    Vault-Tec, adidan and BazzUK like this.
  18. adidan
    25 Mar 2009
    Funtimes.
    Had that done when I was 15 and was similarly rushed in before it burst.
    Hope you're not stuck in there too long.
    BazzUK likes this.
  19. BazzUK
    6 May 2024
    Everything went fine and expected to leave tomorrow, which is a day longer than I would have liked
    At least I have no pain now
    MadGinga, IanW, perplekks45 and 3 others like this.
  20. adidan
    25 Mar 2009
    Good to hear :thumb:
    Arboreal and BazzUK like this.
